ARCHIVED: [ROM][WIP][ALPHA] aospCMod | AOSP 2.3.4/CM7 (GB)
Status
Not open for further replies.
I spent the better part of 2 days trying to install this but gave up after my system kept freezing up on the android screen during reboot. I was able to recover and reinstall the original VM ROM and I think I will stick with that, with Launcher Pro overlay, unless an easier way to install a new ROM comes out. At least I learned how to root, use CMD.exe with adb and flash a recovery. I just could never get the ROM to install correctly.
Easier? It doesn't get any easier lol.
I'm pretty sure that the bump up to 2.3.4 is responsible for breaking a lot of things..
Progress is progress.
Sent from my VM670 using Tapatalk
I've been using the phone as an "ipod touch" device past couple months with aospCMod Rom but now I want to activate phone service with Virgin. When I call to port my number over they ask me to type in ##847446# to activate phone, but nothing happens. Is aospCMod Rom somehow preventing this, how do I activate? thanks
The activation only works on Stock ROM. Check the "Modding Guide" Sticky for information thread on "How to return to stock (Mostly)"
EDIT: I would make a full nandroid backup of your AOSPCMod system first so you can restore to your current setup after activation.
Basically flash the stock nandroid backup and then activation will work.
Then once you're done activating the service go back to recovery and flash the AOSPCMod backup.
(I'm not sure if stock overrides custom recovery. You may have to reflash recovery if so.)
Sent from my Optimus V using Tapatalk
So does anyone have a fix for the clock that doesn't require me to reflash 2.3.3, copy the old deskclock.apk, then flash 2.3.4, and then install it?
Ok, I just flashed the stock rom to my phone, I rebooted, there was a virgin mobile screen, but it is now stuck in the "android logo" screen. What did i do wrong, did I just brick my phone?
how long have you been "stuck"...sometimes it takes awhile
5 min? I never seen it take this long, how long is the max I should wait?
At the android logo, It took my phone 10 minutes to boot up one time, i thought it was just stuck so i pulled the battery out and put it back in and it took like 5 minutes to boot, then it went back to the normal 2 minutes or so.
Edit: Haha, just saw im #1000, yay?
well, I took my battery out and it still didn't reboot, I will wait it out a bit longer, thanks, been 10 min now
Status
hooram95
