ARCHIVED: [ROM][WIP][ALPHA] aospCMod | AOSP 2.3.4/CM7 (GB)
Status
Not open for further replies.
After you check proximity you must reboot
Sent from my LG Optimus V using Tapatalk
Got this working! I had rebooted 3-4 times and it still didn't resolve the problem. For me, I had to Power Off, then boot up again. I wonder if this reset the hardware somehow..
But in any case, to resolve the black screen problem when hanging up your phone, or when you move the phone from your ear to use the number pad while in call. This is what I did to resolve it:
1) Make sure this is checked:
Settings -> Call Settings -> Always Use Proximity​
2) Power off (not reboot!)
3) Power on
My proximity sensor is working now.
I couldn't seem to keep my accounts synced when rebooting I had to add all my accounts over again. This after several reboots... What am I doing wrong? I don't see anyone else with this issue
While in recovery have you wiped all data, cache, format system, ect..
Hey fellas, need testers for bluetooth and audio. If you could PM/or post any unknown bugs with the rom that would help out. aosp needs more testers for the V to get everything worked out.
Downloading now, Ill post my update once flashed.
Ok flashed and BT is still not working, It connects but no sound
I've tried the proximity sensor thing but my screen still goes black during calls and stays that way.... is there any permanent fix for this?
On 3/6, I am able to listen to music with my Motorola S805 Bluetooth headphones, but I can't do voice dialing. Another problem is that I can't enable USB storage after rebooting my phone while it's plugged in on my PC. To work around that, I reconnect the phone. I posted here because I only have five posts on XDA.
Did you do a full power off/power on? I had to do this.
The 0306 ROm seems to be working fine for me. I don't use BT at all, but did try to setup BT tether. Could associate but not pass traffic.
appreciate it thanks
Short Answer: Yes.
But no fix available ;).....yet. Can you get a logcat while this happens?
If you are having an issue and think you have found a bug provide a logcat on pastebin.com and post it either here or XDA. That is going to be the quickest way to find/debug/fix any errors/kernel panics/etc. How to logcat is the first post.
Note logcat must be running while the error happened.
There is also a free app aLogcat to do it for you.
Just flashed this rom, all seems to work well except the bluetooth. It connects but no sound when in call. I tested with 2 different bluetooths
Does anyone know if the mms issue is still being worked on or if its practically a lost cause? I hear that that is gonna be the hardest problem to fix! is that true?
Yes, MMS will probably be the hardest problem to fix, because the code that handles incoming MMS is closed source. I do not know if anyone is actively working on it.
Status
Hopluikla
