ARCHIVED: [ROM][WIP][ALPHA] aospCMod | AOSP 2.3.4/CM7 (GB)
Status
Not open for further replies.
Ok something a little weird.
I came from Bumblebee back to AOSP.
Everything seems to be working great - BUT
Plants VS Zombies was working totally flawlessly on Bumblebee. On AOSP every time I load it, it freezes, have to close & reload it multiple times before its playable.
I did a full wipe before switching to AOSP and to be honest really don't have much installed but GAPPS.
I never get it to go past the loading screen freeze.
Anybody have any clue what is causing this?
So I've been following the forums here at androidcentral for the past few months with my Optimus V and have loved how far I have gotten with being able to flash whichever recovery/roms I want. Love this rom and have only been experiencing one problem with the vibrate function which breaks even after new flashes of the rom. Since Rom Manager has been updated to support the Optimus V I have had issues with flashing so I put back thunderc on it and have been able to re-flash the rom to see if it fixes the issue with vibrate. Last night I flashed and before I went to sleep the vibrate function was working. When I awoke it was no longer working. Any clue as to what might be causing the issue?
Could it be a hardware thing? Like possible failure? Or is it just with only specific ROM you have used?
No because it still vibrates with haptic feedback and such. It just doesn't vibrate on notifications. And as stated before it was working after I had flashed last night. I believe it stopped working after I accidently toggled silent mode on the lock screen this morning. I may just need to re flash and stay away from the toggle... Im using the current aosprom and kernel 6/01.
Have you tried setting the vibrate in message settings? Just a thought
To make it work on cm7 when it freezes press the home button, then open the game again, then it works for me.
Anyone experiencing when ur typing that when a text comes it it auto rotates when the text is received then rotates back? Is this normal?
What IS the difference between the may 31st and june1st updates? Because june1st gives me horrible battery life and I just flashed may 31st over it so I could have the old battery life.
There were actually two 06/01 builds, one had a fix for MMS, and may have had other fixes that seemed to be left out by accident during the first 06/01 build. Can you send and receive MMS?
I flashed the picasticks0.7 kernel and it gave me better battery life. I think the mms was fixed in the June 1st version.
I can send and receive MMS in the 05/31st update .I tried picasticks with 06/01 and I still had horrible battery life and had lots of problems with certain apps, oh and the screen wouldn't tilt when I would turn it :P.
Status
sukarisw10
