[ROM][WIP-ALPHA7][CM10 PORT] Jelly for Optimus V
Status
Not open for further replies.
Re: [ROM][WIP][CM10 PORT] Jelly for Optimus V
Do not install trebucket it will force close!!! And not stop
Just thought I'd mention this, but when I download my cover art using Cover Art Downloader it works until I reboot my phone, then all the album art disappears. Don't know if its a bug with the ROM or app but I thought I'd just throw that out there.
Its proly because of the sdcard issue where things seem to be gone after a reboot. The sd ext scripts will maybe fix it.
Well, if Zack(and I'm sure he will) implements those sd-ext init.d scripts, it will be worth it.
I've got 197 apps installed, using alpha3 + what I provided, and not a single app has caused me any issues.
Only annoying part so far, is the "Android is Upgrading: optimizing 'x' out of 'a lot' of apps..." at every boot.. I wonder how tdm fixed that in CM9, maybe the same method could be used for CM10?
sent from my Zom-"Bean'(CM10 JellyBean).
Well asked him
I used patch but lost home button :banghead::banghead:
Sent from my LG-LS670 using Tapatalk 2
That happened to me once. I think it's cuz the a firmware has a smaller system partition.. .
I think imma leave trebuchet launcher and impliment the scripts when I get home, nitestalkr do I have to be partitioned for these scripts to work?
Yup, they rely on the ext partition.
Same method used in tdm's quattrimus.
Minimum of either 512MB or 1GB ext(2, 3 or 4) partition.
And about the Android is upgrading thing, I think an init.d script can fix that as well.
After flashing the fix while on cm10, yes, i lost the home button. it was quite strange. Went back to zv5 firmware, and flashed it again and it worked. haha it was so weird...
Tested Bluetooth functionality on Alpha 3. It connected and paired successfully. Was able to have conversation without any issues.
Edit: Tried it again, phone rebooted after turning Bluetooth off.
Sent from my LG-LS670 using Android Central Forums
Reactions: andrewnelson23
@nitestalkr
Your patch did not work I moved app 2 sdcard and it deleted itself
I have a 512 mb partition
App2ex fix wasn't able to be simply copied. ES File Explorer won't find the files when placed on SD card. Worst part is that I deleted stuff from the init.d folder already. Good thing I backed up the rom.
@everyone.
This app 2 ext scripts I provided aren't meant to fix movement of apps to the SD card, after flashing the ROM after you pit the files into it, it automatically moves all apps to the ext partition, just like in quattrimus.
You can only apply it as directed in the zip I provided(or if Zack adds it to the next build).
Its app2ext, not app2sd.
I found out that it can only be added to the ROM.zip before install.
So follow the instructions within the zip, using a computer.
sent from my G-T-R.
@everyone.
sent from my G-T-R.
@nitestalkr can you point me to your zip that you made.
@Zackman, instructions are included in the zip, this is NOT flashable(however, I will include this in all of my patches I made, by Saturday.), and this is to be implemented into the ROM.
Follow this post. ^^
That post up there ^^^
Reactions: r0gu3dev1pr
I'm still really stumped on this native app2sd problem. Replaced the vold files, that didnt work, replaced bin files with others from a different rom, that didnt work, replaced librarys, got bootloop :/ dang. This is going to be difficult.
what problem? whats happening
Status
Bantuan
