[ROM][WIP-ALPHA7][CM10 PORT] Jelly for Optimus V
Status
Not open for further replies.
I'm going to work on an app to SD-EXT script for you Zack, and you could place it into your ROM.
Its going to be identical to the one in quattrimus, but I'm going to see if I can make it appear in the storage settings too.
sent from my un-dead sammich.
I'm just curious, but what made the launcher have the icons overlap things? I've never seen it before :p
I'm assuming that its due to our screen resolution, and the launcher was probably made for a larger resolution.
sent from my Zom-"Bean"(CM10 JellyBean) .
Yeah that's what I was thinking, is it an easy fix? :o
Re: [ROM][WIP][CM10 PORT] Jelly for Optimus V
Use a different launcher xD maybe zakman could put a different one in alpha 4
ya im guessing the launchers jb and ics are not that different
got dsixda kitchen setup :)
but when i extract boot image i get Z image
and ramdisk something
i searched for kernel file and could not find it
The launchers aren't that different but there are differences. The jellybean source cannot be compiled against the ICS framework so there are some significant differences, but its probably under the hood
Yo y'all are killing it with this rom so much progress is unreal great work guys , my hat goes off to y'all . Just waiting for the borked SMS to be fixed and the camera cause I need that and as soon as that is fixed it'll be dd:D
REKCITY
hey all i have a question
would the apps2ext fix the apps going bye bye problem
I am currently working on the app2ext issue, and i'll be testing it via flashable zip on top of alpha3, and if i am successful, i'll upload it to be implemented into the ROM.
Reactions: jonny5449
Status
lefler
