[ROM][WIP-ALPHA7][CM10 PORT] Jelly for Optimus V
Status
Not open for further replies.
Re: [ROM][WIP][CM10 PORT] Jelly for Optimus V
I was having problems signing in to my Google account after first time setup, and I think I noticed "Google search has unfortunately stopped" popping up each time I tried to type, so I went and disabled voice typing and keyboard now works.
Also flashed jellybean super fix, and seems to be working well. sd-ext works as well too.
I'm assuming this has the usual CyanogenMod goodies, and is less AOSP-e? :D
And I got permission from tdm to make a flashable zip of his 2ext scripts, I haven't gotten around to it, but expect a zip by the end of this week(or sometime during) to be made.
sent from my Zom-"Bean"(AOSP JellyBean).
Reactions: inceyet
I doubt it. Cm hasn't implemented most of them. Last I checked on CM's git at least
Actually it is very cm-ish.Only thing I've seen not implemented is themes.
I did not get the gapps installer, but I was able to sign in to my gmail account just fine when I opened the play store.
I had to follow this route also.. Awesome work.. Thank you.
Sent from my VM670 using Tapatalk ? to here.
could you put up the md5 sum of both the rom and gapps? I did it again and again, never got the setup at the beginning, and again, home button doesn't work..
yes. I think the problem was that I was on zvd radio. I moved to zv5 and got the setup. home button works for me now. I also have lockscreen. WOW, so many things depended on the radio....that's strange.
I came across a few issues, nothing minor, but wanted to let you know Zakman:
- color banding was not patched via super fix
- keyboard does not display the punctuation bar at the top of the keyboard, only within the keys
the keyboard issue may be related to it being installed on the sd-ext partition, but most likely not. Very good and stable rom for being in alpha, nice work.
So I went into google now, and got the expected force close. after that I rebooted and found a weather card in my status bar :D
I'm not getting color banding. Are you on an optimus v?
Thought this was cool. Didn't notice the Google at first.
Status
dhickman
