[ROM][WIP-ALPHA7][CM10 PORT] Jelly for Optimus V
Status
Not open for further replies.
Everything is great except the apps from the play store my Facebook is like a year old loll
Re: [ROM][WIP][CM10 PORT] Jelly for Optimus V
Anyone have an Idea on how to fix the app to sd problem?
Use the sd-ext partition scripts. I think it's because of the usb mass storage thing.
I MIGHT have fixed mms, but I have no way to test, as I'm in a place with very little service. Could someone test for me??
Hold on and I'll mediafire it.
Edit: Well I keep getting a "unfortunately, the process com.android.phone has stopped error", so I'm going to try and work that out before I upload.
Edit: I don't know what I'm doing. Didn't work :( sorry if I got anyone's hopes up.
LOL I actually like that, I've found the new versions of the Facebook app to be really slow when loading the news feed and stuff.
Don't mind Facebook app but I can't get quick settings or YouTube :P
Still not able to get voice mail. I saw that
Code:
ro.cdma.voicemail.number=mine
is in the build.prop already, so I don't know what the deal is...anyone else not get voicemail?
Code:
Try dialing your number instead of tapping the notification.
The notification goes to *86, which is the Virgin Mobile line.
sent from my Zom-"Bean"(AOSP Jellybean)
Reactions: andrewnelson23
But it runs super smooth in jellybean. Only part that takes a while, is logging out :p
It says i can't download "E:No signature (1001 files)
E:signature verification failed
installation aborted", any help?:O
Just flashed on my Optimus S, with the ZVj/ZVD baseband switch and it works awesome. Tinkering with it now, will report back issues.
Thanks Zakman!
Reactions: nitestalkr
Okay, I swapped the apns-conf.xml and the cdmasmsdispatcher.smali in this rom with the ones from quattrimus. I booted and I have service and no errors or anything, but i have no way of telling if mms works or not, as I live in a place with very little service. Would someone be willing to test this to see if it works?? If it doesn't work, I probably still need to add some lines to the build.prop.
Here :)
Edit:
I'm 85% certain this works. I sent myself a picture and received it. waiting on it to download now, but it takes forever since I have such awful service :P
YES! it works. Both sending and receiving mms work now :D when you send mms, it might say "sending" indefinitely. It still says sending for me, but I received and downloaded the picture I sent to myself :D
mms send confirmed (without the indefinite sending message). mms receiving confirmed as well :)
edit: where is cm10 settings? i cant find them. lol
edit2: where is the camera icon?
There is no cm10 settings just like in cm9 there all kind of built in
1 hour off of full charge lmao! That's so baddd
SWEET. :D Thanks for testing.
No cm10 settings: they're all built in. Go to system, and there's some useful stuff, as well as developer options and performance.
The camera icon is not there because the camera doesn't work yet.
Status
richardgroover
