[ROM][WIP-ALPHA7][CM10 PORT] Jelly for Optimus V
Status
Not open for further replies.
I don't think I have access to that download link... it says something about "authorize download"
edit: never mind... it's late for me... lol
It says:
set_perm: some changes failed
E:Error in /sdcard/cm-10-Alpha8.zip
(Status 7)
Installation aborted.
Redownload, disable signature verification in recovery, flash. That should work.
sent from my Zom-"Bean'(CM10 JellyBean).
Here's Alpha 8 for testing only: cm-10-Alpha8.zip
I loves me some Ports 'n Beans.
Flashing as soon as it downloads.
I believe alpha 8 test has an update-scripting error??
Redownloaded at least 10 times(persistent aren't i?) And each returned the status 7 error as mentioned earlier.
Yuppp simple update script fix. I'll do it when I get home, alpha 8 is a complete lib and etc overhall. It fixes app2 SD native (hopefully) and camera.
I'm sure this wont matter with alpha8 and going forward, but when I loaded alpha7_2 I used link2sd to force all of my apps into sd-ext, dalvik-cache, etc; basically had it set to move as much as it could and to do so for every new app install. I've had no problems with it. As in to say I have not yet had the problems others have reported where the apps would just disappear.
Also wanted to point out that native AP tethering doesn't work; similar to the various ICS roms you can find here.
Fixes camera???!! a;lsdkfj;alskdjf;laksdjf;lkj I'm so pumped. As soon as the update scripts get fixed, it's becoming my new daily. :D
Cmon zakman release alpha 8 :p
Lol lol jkjk
Take your time can't wait to fix camera in my rom
Sent from my LG-LS670 using Tapatalk 2
Status
MatthewD
