[ROM][WIP-ALPHA7][CM10 PORT] Jelly for Optimus V
Status
Not open for further replies.
I seem to have fixed the switched home and menu key problem, by going to /system/usr/keylayout/thunderc-keypad.kl and changing a few keys (139 and 102) around.
key 139 HOME WAKE_DROPPED
and
key 102 MENU WAKE
Simply switch the HOME and MENU text around:
key 139 MENU WAKE_DROPPED
and
key 102 HOME WAKE
Then save the file, and reboot. Works so far for me.
and
key 102 MENU WAKE
and
key 102 HOME WAKE
Encorperating into new rom and reuploading as we speak.
How is the battery drain on this rom since you have implemented 4.1 kernel? Still the same? improved?
I have a bug in gnow when I scroll the search bar scrolls not the page
and
key 102 MENU WAKE
and
key 102 HOME WAKE
i have tried this like 5 times....and nothing happens :/ i go back into the settings, and its like it never saved even though i saved it. lol
and
key 102 MENU WAKE
and
key 102 HOME WAKE
I reuploaded the ROM with the keys fix, just redownload alpha 7
1. havent noticed yet, but only had it a day.
2. mp3 cannot be used directly as ringtone, but easily can be made into a ringtone using Ringdroid, free android app off of android market. This app can also be used to edit/chop up mp3s to get exactly the loop you want...pretty sweet. honestly though, I would like if mp3 could be selected straight up as a ringtone.
3. You can check gmail through the gmail.com webpage on the phone, or you can also log into "Gmail" application on the phone which appears to only handle 1 gmail account at a time. So, no, no-multiaccount notifications, I would say. Very probable that someone will come out with this in a custom app though.
Custom apps man...get what you want out of the phone.
:what:
I will DEFINATLY look into it
EDIT:wrong quote:o
Sent from my LG-LS670 using Tapatalk 2
So I've been away for a couple days. The latest alpha 7 had the button fix AND the new kernel correct?
awesome battery life
I left the sync, gps, and 3g off in airplane mode and it stayed at 100% for the whole school day (7:20-2:36)
Reactions: Zakman
Status
SamuraiJack1981
