[ROM][WIP-ALPHA7][CM10 PORT] Jelly for Optimus V
Status
Not open for further replies.
Uh oh. :( dang. the mms is working now, but now the sms isn't. which means I'll have to try and edit the cdmasmsdispatcher.smali according to the quattrimus one and only include the mms items. hopefully that'll fix it. i'll start working on it now.
Note: sms receiving IS working. Sending is NOT.
K. Thank you for your hard work
That's kinda funny, cause at one point I was able to send, but not receive.. but this was after trying out(and adjusting) an external notification light script for the Optimus V (flashes hardware buttons when there's a missed notification when phone screen was off).
sent from my Zom-"Bean"(AOSP JellyBean).
Re: [ROM][WIP][CM10 PORT] Jelly for Optimus V
So I was looking at the .smali right now. I did a number count on mms items and virgin items and all of the mms and Virgin items that are included in quattrimus were already in the alpha1. the code remains the same through 700 lines and then it starts drastically changing at 705. I'm gonna try and look through(roughly 1200 lines) what seems important, but I have no experience in programming or anything... :/
Then it looks like your experience starts now. :p
I might as well have 0 experience, the last time I did any real programming was nearly 5 years ago! :p
This is going to take a RIDICULOUS amount of time since I don't know what I'm doing. but for now, I'm going to try replacing the entire cdma folder in the classes.dex, hopefully that'll work, but I really doubt it.
Oh how I know exactly what you're going through.
That's usually what I used to say all the time(and still do) with nearly everything that I do. xD
Patience and endurance are key. :p
tried to replace the cdma folder, that started producing an error "unfortunately, the process com.android.phone has stopped." That happened over and over and over again. No service. I then tried replacing the entire telephony folder. Gives me the same error. So far we're best with the cdmasmsdispatcher just replace. I guess I (or maybe someone more knowledgeable??) will have to go into the cdmasmsdispatcher.smali and maybe edit the info in there.
I just helped a Nexus S 4G owner port jellybeand from the Nexus S. He was able to get everything working and he replaced the /system/etc/permissions with CDMA permissions and I think it worked for him. Run a logcat
im so abouta try this
everything in alpha 1 worked great except the camera. since my camera seems to have a mind of its own lately (whether it wants to work or not) i might just go to this JB rom and stay there :)
Beast. haha okay. Ill run the logcat with cm10 alpha2.
noticed something, and i dont know if it could be classified as a bug. im using wp7 notification plus, and on the banner (top part of the screen) when a message comes in, its supposed to be a colored bar...in my case its lime green. but theres no colored bar, just the text
edit...all of a sudden, my sms isnt working. and im using the same file i did previously. weird :/
New thread about mms fixing. please go here for logcat and cdmasmsdispatcher.smali files.
Status
Ycossbarmo
