[ROM][WIP-ALPHA7][CM10 PORT] Jelly for Optimus V
Status
Not open for further replies.
Re: [ROM][WIP][CM10 PORT] Jelly for Optimus V
Is it possible to use an optimus One kernel on our V?
also, since jb is different then ics, i don't think we can use an ics kernel.
why not? ics is different than gingerbread, but we use gingerbread kernels...
Good work! :D I'll probably be flashing tomorrow, its already my DD
Reactions: Zakman
Encryption??? Can we encrypt our phones with the encryption setting?
Sent from my LG-VM670 using Xparent Pink Tapatalk 2
Well, in the next release imma use
The cai alpha15 kernel. Run 10 times faster and probably has better battery life. Also, I've gotten the storage in system settings to work but now when I try to move an app it doesn't detect the SD.
Reactions: Master Gowa
Couldn't wait to try this so I did a clean wipe and jumped on Alpha 1 right before Alpha 3 came out. So I did a dirty wipe and upgraded to Alpha 3. Seems like it's running great but I've got nobody to test the SMS and MMS with at the moment. I don't think the sd-ext scripts worked properly. I have a 1 gig EXT4 partition but Titanium Backup didn't list it. Also the roms storage menu crashes. Aside from that... I'm loving it. Thanks for the hardwork.
How come some apps from the Playstore are fine but others are now incompatible? Will a Titanium Backup of an app from ICS work on JB or are some apps really incompatible now Viber and Instagram worked on ICS but the Playstore now won't let me download them.
They're incompadable Cruz jellybean is a new os and not many app devs have updated yet.
i checked the changelog for alpha 3, and the only thing i see mentioned is a new tiny keyboard. does this mean that the sms/mms issues are not fixed?
Status
fulapmu2
