[ROM][WIP]CM10.0.0-RC0-BobZ
yeah, all up to date for the sdk.
I just updated my SDK to 4.1 and still can't get adb working either. ICS was working before because when I originally installed the SDK I opted for 4.0.x support.
Anybody else having this issue? I re-installed the 8/22 version, thinking that it had worked with the 4.0.x adb, but no luck.
Use the littler, BobZ, one. :)
Lol yeah I know, I I did that. Was just commenting on it.
Well the rom runs beautifully, I got tethering with both barnacle and wifi tether for root users but as of right now the lack of space kills it for me. I installed a couple apps and was down to about 30mb free. On the bright side I moved a few things to the sd and they were still there after a reboot lol.
Looking forward to progress
Doesn't work for me. Any other settings you modified to get brightness to change?
I just went to settings>Status Bar > Brightness Control
Just and FYI though I just went to the normal brightness setting and I can use that slider too, so I don't know why you cant..
This ROM runs fairly well. But I can't install all my apps. I do have 1gb SD-EXT but Titanium reports that I have 700mb left to use. B
So I thought it should be able to handle it.
Has anyone had trouble with YouTube running completely? I can load a video but within 5 seconds it soft resets the phone.
Sent from my Optimus V via Tapatalk
Yea it's likely though I remember YouTube working okay on CM9 ICS. Of course video drivers could be quite different in JB.
I watched a 7 minute video without it rebooting. But that was after it rebooted once.
Also, I just got an MMS... so at least its working in one direction.
Read about 2 pages back about a2sd++
So did you get a2sd++ working? Are you able to install more apps?
a2sd++ works for me perfectly; int2sd did not. I have around 40+ apps with google+, facebook, maps, google music, swiftkey, angry bird and instagram included in that list; those are the largest apps on my phone ranging from 18mb - 30mb.
I don't understand why int2sd doesn't work. I've read through the code and it seemed pretty straight forward so either I am not reading something right or the flash just didn't stick. Everything that I want on my phone works for the most part and everything is setup so I am reluctant to go and spend time re flashing just to try again; I'm mostly just an end-user that likes to tinker when I have time.
Here are some screenshots of what my storage looks like using a2sd++ (I assume based on the first image that I am using 16MB on my internal memory):
It did for me for about ten minutes. I let the phone sit for a little but and it sorted itself out on my phone.
Same here. I have about 30 user apps installed, with 35MB internal memory used/144MB free. I used clodfelterac's directions on Pg. 9 to insert the a2sd++ script into the ROM before i flashed it. Without it, I could install only about 15 user apps until the internal memory was full.
Just for documenting here, I didn't follow clodfelterac's instructions. I basically just followed the devs instructions at XDA in that all I did was flash the script.
so basically my steps were:
1) wipe data, cache, sd-ext, dalvik
2) partition sd-card (2gb sd-ext, 0 swap)
3) mount sdcard
4) adb push bobz rom, gapps, a2sd++ scripts
5) flashed Bobz rom
6) flashed gapps
7) flashed a2sd++
8) reboot
jbolee83
