[ROM][WIP]CM10.0.0-RC0-BobZ
Updated OP...sorry for the delay!
I haven't had any data issues lately, but I'm still on baseband ZV4!
Awesome build. Thanks Bobz for making this LS670 friendly. I think a2sd++ was a good choice. It seems to work very well.
I am ZVJ baseband. I will let you know how the data seems to be working later today after I have a chance to play around with it.
Great build Bob. I was having some issues at first but after a while, they went away.
Just tested 9/15 build. Now there is an microphone problem. the old voice search no longer works, but mic in calls works.
Updating to your latest BobZ. Can't wait to see how the battery life is with the brightness fixed.
Sent from my LG-LS670 using Android Central Forums
just installed this rom. its pretty awesome :) two things though how can i get voice search t work? and also google now wont scroll
Ok the new version uses a2sd++ so theoretically space shouldn't be an issue anymore correct
Latest build is so far so good. Data is even properly connecting after I turn off WiFi so Thats good.
The folks that had the original a2sd++ installed may have issues, because it was also moving apps-private and apps-data to your sd-ext. I was having a lot of weird issue with my phone, until I realized what the problem was. My edited version of a2sd++ leaves the info on the phone, so it gets wiped when you go to flash a new rom.
Voice Search, Voice Actions and Dragon don't seem to work. At first, it told me that it couldn't open the app. I removed and re-installed Voice Search. Then I would get a mix of FC's and "Didn't hear a voice" type messages.
LS670 /w patch
voice is broken for me as well. i tried reinstalling it with no dice. rom is nice and stable otherwise compared to the previous build.
edit: camera has a glitchy look to it, however panorama mode works (slow as crap but it works.)
stopwatch
