[ROM][WIP]CM10.0.0-RC0-BobZ
So what you guys are saying is the keys are messed up? :confused:
Just the home and settings are swapped. Honestly I don't see why everyone worrys so much about it. I could care less but that's just me lol. :D
It's switched...? When I flashed when he released it, everything was normal.
Or did he release test builds?
On bobz release, menu works but home selects, I swapped input.so and now keys are s keys, I believe its a kernel problem
I know this has nothing to do with this, but:
I'm leaving on Thursday to Florida, and Ive never been on a Plane before. On a Plane, am I supposed to turn Airplane mode on?
EDIT:
I just noticed this was CM10. I mistook it for CM9, I flash CM9, not 10 :o
It's not a kernel problem, because I'm using the same kernel source as CM9...which has no key issues.
I sync'd with CM a couple hours ago and it broke my build environment...I finally got it fixed and compiling now.
@bob
Gotta love it when that happens. I'll probably have the same problem when I get home.
I did... its tapatalk. Lol
Edit: fixed. Kind of lol
Yes. No calling during flights either (that's what airplane mode gets rid of in the first place).. You can use in flight wifi if they have it (you have to pay though, if they offer 15 minutes free, get a mac changer to extend it). They also don't allow bluetooth. You have to turn off all electronic devices until ascent to 20 thousand feet or so. Have fun in Florida!
Reactions: ThatGuyLurkin
I haven't tried cm10 yet but if doing this gets you OS layout.. Then in /system/usr/keylayout if you swap keys 139 and 102 in the thunderc_keypad.kl and qwerty.kl you should have normal OV layout. Unless I'm way off and things are different in cm10
Tapatalk'n it from my VM670 running Kool-Blue_2.3.3_V2.2 on LS670ZVJ Baseband
Reactions: StingDrop
Holy moly, how did I miss this?! The title looks very similar to your CM9 thread I just skipped over it most of the time! Awesome job here!!
Yeah just swapped that and it works!!
Can't wait for a beta! :)
That's a LONG ways away but it will get there:D
Sent from my LG-LS670 using Tapatalk 2
Wouldn't be to sure. BobZ work is amazing. He made my ICS love go way up now that I can over clock with no problem. Jellybean is close to Beta from the feel and performance.
Id call it beta when the keys are fixed... never underestimate bob, the guy is a genius. I couldnt even get it to compile!
Reactions: BobZhome
Currently running bobz cm10 with keys fixed and I'm loving it
Reactions: BobZhome
periyasamy
