[ROM][WIP]CM10.0.0-RC0-BobZ
One more question, did google account sign-in occur on first boot at all? Or did you add the account after booting up via settings?
Sent from my Optimus V via Tapatalk
First boot up
Another bug: the key backlights (LEDs?) stay lit when the screen is turned off.
I've noticed that the LEDs have turned off before without a rooted app, like rootdim, but it takes a while for it to turn off.
So, all the other issues from CM9, like GPU drivers have been resolved on this CM10 ROM?
The graphics driver issues are not solved here, and likely never will be solved due to Qualcomm's unwillingness to release them compiled for ARM6 (unless someone figures out how to reverse engineer them or make a wrapper for the GB ones- both of which would be very difficult tasks).
Reactions: r00t
I did a full wipe, flashed the ROM and flashed my gapps and it work perfectly!
Tried flashing both yours and the gapps provided in the OP an still a no go on the Play Store.
Probably cause i modified the zip and replaced latinime with the 2mb one
This home key is troubling me, what files are used for the Buttons/Keys in the android file system? anyone know?
If it isn't much trouble, could you upload this modified zip? I still cannot get first time account restore, it goes boots straight into the home screen.
These darn keys!! I can't seem to fix the key issue ATM will keep trying tomorrow, for now I'm using button savior, gonna get some rest now, brb tomorrow
Got GApps to work by moving them to /data and to their respective folders. No glitches or durps, I think we can get gapps to fully work by pushing it all there.
So we just need to write some custom GAPPS and we are all good to go ;)
if we change its ownership to root and chmod them to 644, we are good :)
@bob maybe if you make another build from source when it updated the home key will be fixed, i cant figure out whats causing it :/
So the home key prob is not in thunderc.kl or that other file.kl
Sent from my LG-LS670 using Tapatalk 2
believe I found the files causing the selecting error: its input.so in system/lib/bluez-plugin
@Bob also the kernel has a menu and home buttons swap on it, maybe something to look at
djdjjkzzz
