[ROM][WIP]CM10.0.0-RC0-BobZ
Has anyone else noticed that adb reconnect doesn't work?
It didn't work in the initial release or the update this month. The phone does not show up you try to connect with adb over usb.
adb over network does work however, if you enable it.
Please bare me. I haven't kept up with rom releases and I'm coming from BACKside (I know).
My data is on my sd, how can I make an ext partition and do it without losing app data?
Are there still problems with deep sleep mode? How's battery life?
How often does 3g disconnect?
H
H
You'll have to copy your SD card to a PC if you want to keep any of it. Partitioning the SD card will format it.
Battery life is fairly similar to other ics roms.
3g disconnects if you're on wifi for a while. I just turn it off when I don't need it, and turn it back on when I need it.
Whats good yall ive been really and havent kept up with this too much just wanted to know is the op up to date with whats working and not ....wanted to try this out but I need mms camera (camcorder not vital) im on tgl gs3 right now (btw its sick)
So can titanium backup be used to restore apps later? I'm not sure how that would work since newly installed apps are moved to the SD, right? Or does the script handle all of that?
I have made titanium backups of apps on cm9 with the same script and restored them on cm7 roms without the script. I think the script is invisible to titanium, and it "thinks" it is dealing with the data partition, when in reality it is installing to the sd card.
Titanium reads the install location from fstab of the system. Weather that's pointing to internal memory or the SD card, TiBu doesn't care.
Repensum Est Canicula
Hey everytime I try to install something I downloaded of the internet it says parse error
Any way to make my installations work??
Can you be more specific? What are you installing? What recovery? What rom? What steps are you taking?
So I've been on Bobz ics rom for about a week and its great I, is moving up to this rom better or should I just stay on ics
I do love the jelly bean elements. Give it a try and see what you think. Just make a backup in case you don't like it.
Anyone check out "optimus one cm10 rom editor"? I would love to try it out but I guess not having Windows is actually holding me back this one time lol
come to the dark side
It will not work for the variants on Verizon, VM, Sprint, US Cellular, Metro PCS or Cricket. Essentially none of the CDMA variants.
The Optimus One is the P500, P506 and P509. So basically the intl', AT&T and T-Mobile.
I think the build.props are totally different...
Just one question before I try it, does this rom get deep sleep?
Abheetha Athukorala
