[ROM][WIP]CM10.0.0-RC0-BobZ
brotherswing...seems to have improved for now. Will see how it is a few days from now.
Why did I have to press down Power for 30 seconds? Just curious. And clear data off the phone app?
I believe it resets the phone. Not sure though.
Sent from my HTC Evo 3D using Android Central Forums
The mic doesn't work with apps on this release. Two releases ago, it was working, but I don't remember the date on that one. If you read back a bit in the thread, you should be able to find it.
Is there any kind of work around for this?
A lot of times junk data is floating around in the memory. Rebooting helps, but if the junk is in the system areas instead of ram then the power button trick is needed. It forces the phone to clear out all of the memory, including anything still in the cache and system areas. The next step after that would be clearing the data for the whole phone.
Repensum Est Canicula
I am determined to get my mic to work with this rom, for I rely heavily on it sometimes. I found a maybe solution here Install Google Now With Fully Functional Voice Search From Jelly Bean On Any Android 4.0 ICS Device | Redmond Pie
The problem is that when I try to paste the new apk into the system app folder using root explorer it gives me a low storage error. I need to free up about 9 mb of rom space. Any suggestions? Also, how do I clear my cache? ES file explorer does not seem to work for clearing cache on this rom.
I don't think that will fix the mic problem, as it doesn't work with any apps, but feel free to try. You need to delete things from the system partition. The obvious things include ringtones and wallpapers, but you are gonna have a hard time finding a significant amount of space there. I don't remember which keyboard Bob used, but there is one that is less than 2mb that you could try.
You can clear your cache in recovery.
What I am noticing is that there is no voice search in the loaded apk within the system app folder although it reports as being installed in Google Play. This could be the issue?
I think it probably has something to do with a lib, or some other system file. I doubt it's an apk problem as it affects all apps (several apks). I have resigned myself to waiting patiently until Bob has time to work on the rom. He has said he should be getting to it next year.
See, that's why i was waiting patiently. Thanks for sticking with this rom, Bob!
Sent from my GT-P7310 using Android Central Forums
That is a known issue, but it should take good pictures.
Does anyone know how to change the carrier name on this rom?
Sent from my LG-VM670 using Xparent Cyan Tapatalk 2
Like in the notification window? You must decompile framework-Res.apk, edit eri.xml to your carrier name, recompile and put in /system/framework.
Sent from my LG-LS670 using Android Central Forums
uimahe
