[ROM][WIP]CM9.1.0-BobZ
Re: [ROM][WIP]CM9.0 RC1-BobZ
Everything working good for me so far, love it! Only issue (other than the obvious ones) my bluetooth doesnt work, in fact when I mess with bluetooth at all my phone reboots.
Great job, keep up the good work!
does this sound like anything related to the screen splitting issue?
CONFIG_FB_TILEBLITTING=y
"This enables tile blitting. Tile blitting is a drawing technique where the screen is divided into rectangular sections (tiles), whereas the standard blitting divides the screen into pixels. Because the default drawing element is a tile, drawing functions will be passed parameters in terms of number of tiles instead of number of pixels. For example, to draw a single character, instead of using bitmaps, an index to an array of bitmaps will be used. To clear or move a rectangular section of a screen, the rectangle will be described in terms of number of tiles in the x- and y-axis.
This is particularly important to one driver, matroxfb. If unsure, say N."
this option is not set in tdm's build
Where is that located? :0 build.prop?
Reactions: A-android-B
Just wanted to say thanks for the awesome buildz.... My girl finally let me root her phone last night and after about an hour I had the 7/3 build up and running perfect. she couldn't be happier. Now, if they would just give us thunderbolt users the RIL we to could enjoy in some legit CM9!
Keep up the good work!!
I just wanna say that BOBZ for barely releasing this rom its more stable than quattrimus. Its an honor to try your roms. Can't wait to see what you will do in a month. Mad props bro!!!
Reactions: BobZhome
Weird. What recovery are you using? I'm on cwmt and I've had no problems with flashing. I don't use wipe zips though just wipe in recovery. Just cache and dalvik cache for dirty flash. Factory reset from recovery for clean flash
The last rc0 release worked with tether for root user. Both the rc1 releases do not. Revert to rc0 and works fine. Is it just me?
ahsokacat
