[ROM][WIP]CM9.1.0-BobZ
Re: [ROM][WIP]CM9.0 RC1-BobZ
Does voice transcription work? I noticed the icon doesn't show up on the keyboard. I know voice actions works but I'm referring to the one that lets you talk as your keyboard in any application. Also is it possible to toggle hide the status bar?
Thanks! the OV sure has come a long way since when I first got it.
im using the xionia recovery. what do you guys use
This is what I'm using and most are on now flashed with GUI thanks to clodfelterac
"i renamed it to drewsnewrecovery.img and it has worked via gui or terminal with no problems at all... tested multiple times"... try it out
Thanks to drewwalton19216801
http://forums.androidcentral.com/showthread.php?t=180992
[RECOVERY] Cannibal Open Touch v1.2 (latest update: 06/24/2012)
AOKP, G-T-R, MiRaGe, Godzilla, JOYOS, Harmonia killing the game!!!!
There is a bug everyone has overlooked or is it just me the light on the hardkeys stay on all the time no matter what
:confused:
:confused:
I have noticed that the lights stay on if I have wifi on and I'm charging my phone at the same time. If I either turn wifi off or unplug the charger then the lights go off. The isssue is not very high on my todo list...
Sent from my GT-P3113 using Tapatalk 2
Don't know what it is but ever since i flashed the 7/3 build I've noticed drastic battery life gains
Don't know if its a known issue or not but my key lights aren't on at all.
They've never turned on with this rom , no big deal saves battery, if you want them to light up go try the other ics rom, they the hard keys stay lit all the time
Reactions: drm1992
I feel like I get a bit less battery life with this.. funny..
New info down at the bottom ...
Hi, BobZ!
I have an issue with playing movies and it seems to be common to ICS, not just your build, because it has happened with another one too.
Once the movie plays past 1:12/72 minutes it loses sync between sound and video. Video pauses and I just get random stills and the sound track plays on at what appears to be normal speed but it isn't coordinated with the still images other than that they are both moving forward.
I have tried going back to the beginning of the track and using the controls to scan forward. No change. Same thing if I go to the end and scan back. Sometimes I will get the video from the time I have selected but the sound track will be from just a few minutes into the film. I haven't been able to figure out a pattern yet. Just have these observations.
All of the movies I am viewing came from a single source though. They were re-sized to play on the Rumor Touch. So the problem could be in the videos themselves. Have you seen this?
Anybody else seen it? It might be just the videos I have. I'll try to get some more to check on this.
Instead of getting new videos I copied the existing ones from my 'puter over to my other phone (yes, I have 2 vs). It is running the latest MiRaGe and the videos don't go crazy after 72 minutes. They play all the way through smoothly to the end.
Has anybody had any luck with the white screen on Facebook
If you don't need photo upload or notifications, then try tinfoil or just the browser. The browser based version is the same experience.
Reactions: drm1992
Bob I flashed your rom the other day and got a split boot animation going on :confused: I've heard that others are having the same issue... is there a solution or work around just curious cause its happened with sellers - cna and torches Godzilla. Thanks in advance
jojomojo
