[ROM][WIP]CM9.1.0-BobZ
Thx a million @BobzHome. I can finally overclock a CM9! The new kernel is the shiznit! Anyone tried flashing the amphetamines or the disable gpu rendering?
Reactions: BobZhome
I'm running the latest release with amphetamines and egl patch. Its so sweet even the brightness control via swyping the status bar is smooth. Thanks again bobzhome.
Reactions: BobZhome
Question, as I may have spoke too soon. After I rebooted once after flashing and overclocking, I've gotten a few FC now so what changed after the first boot after OC'ing?
Anyone else experiencing this? Package File is Invalid, while updating from play store?
**FIXED** I went into Manage Apps, removed Updates and opened Play Store back up. It re-updated and works fine now.
I reflashed and retested... my notification sound does not go off no matter what. I don't get it
Weird blue screen anyone? Happened after turning screen back on from a 10 minute break in playing on my OV.
The only problem I ran into is that when opening the Camera it can cause a soft reboot. The screen would go black, still on, and not so anything.
Could be my over clock though.
Where are you OCed to? I'm getting reboots at 480 and 748 using SalvagedZen. Anyway to get offline charging back or is that completely out of this rom?
Offline charging is kernel governed so you can't just "switch it on."
I'm running
320/806 Smartass2
I actually prefer Online Charging. I reboot a lot due to testing. Offline charging kills the reboot.
Re: [ROM][WIP]CM9.0.0-BobZ
Also noticed that my audible notifications are only playing through the phone speaker when using a bluetooth audio device. The volume lowers (when playing music) like usual but the audio never goes through the BT device.
this is known with ICS. does it with headphones too.
Anyone know why I'm still getting Invalid Packet Data when I try to update or install anything from Play Store?
Is there any way to fix this? It's really annoying, and the only thing keeping me from finally switching to ICS.
it would most likely have to be done in source, and audio routing is nasty. dont expect it to happen anytime soon.
Apexmaster40
