[ROM][WIP]CM9.1.0-BobZ
Re: [ROM][WIP]CM9.0.0-BobZ
from the 7.27 build, do a dirty flash or clean wipe for the 8.16 build?
Flash doesn't work on dis rom?
Bob... you never cease to amaze me (I don't know how many times I've told you this). Keep on with your bad self. >.<
I don't really post on these forums too much; more of a lurker, but I was wondering if anyone has managed to fix the battery graph bug for this ROM. I have a theory that the issue may stem from the lag of the system clock. This is very minor, just curious.
@BobZ: Great work on this ROM, I've been using it as my daily driver since release.
I am still having problems with ics freezing and reboot. I use leslieAnn prep for new rom zip, flash rom, flash gapps, and Reboot. It used to freeze on the first boot, but I think the new build fixed that. I overclock 480/806 using SavageZen. As soon as I do it freezes and reboots. What am I doing wrong? It has done it with all the ics builds. Somebody help please
Same process, but overclock, 480/600 (Your choice of Governor)
I flashed the latest not long ago, and wow. ALOT faster than Quattrimus for me. I had ine random reboot when messing with settings, going back to CM7 now. :)
Good job Bob! :thumbup:
I like how it says RC0 and we are all running RC3 :p
What you didn't notice was that it said Cyanogenmod 10. Which means he is building Jellybean. Can't wait for this. Zakman's CM10 port is already more stable than most CM9 roms. With Bobzhome on the case... CM10 should be hammered out in no time. :)
Remember guys, that was just a simple teaser shot, if Bob wants to explicitly allow "Bobz CM10" speculation and general excitement discussion here (p.s. I am SUPER PUMPED), go for it, but until then, keep this thread about CM9.
Oh. Wow. This is monumental.
I heard about CM10 nightlies being released tonight, just wondering if that might catch your attention Bob :)
Sent from my LG-E739 using Tapatalk 2
BobZhome,
You are the man. The squareup reader totally works in yesterday's build: CM9.0.0-VM670-BobZhome (8-16-2012). Thank you so very, very much.
Germitty
sarahsda
