[ROM][WIP]CM9.1.0-BobZ
Unfortunately, I'm still experiencing the white screen issue quite a bit (had to reboot 2 or 3 times today because of it) even with the latest CM9.1 build.
Not sure why but it always seems to affect the same apps for me - Gmail, Dolphin Browser, and to a lesser extent Touchdown. Other apps seem to work fine.
I had a white screen in one Gmail this morning.
So, is there anything we can do to help pin this issue down to a specific? Should we try to reproduce it while plugged in with USB debugging enabled to get a logcat? Would that help?
Let's hope I'm tired of wight screen in FB durring class :p
Go for it, it doesn't hurt to try...but really don't think it's going to show an kind of error. Please use pastebin.com and just post the pastebin link, Thanks!
I was kind of hoping to inspire someone else. My data cable has a short, and I've got no internet access at the moment.
Partial view of the logcat... it looks like the webcore thing might be the problem. I closed all other apps before running Gmail and the logcat app. As soon as the email showed white, I hit home and powered up a logcat app to instantaneously generate a log.
I'm having problems getting WiFi Tether to work. I'm guessing that I just have the settings messed up somewhere. Could someone post the correct settings to use? Thanks!
I use Barnacle Wifi Tether, and it works fine.
i would run the logcat before running gmail, so it can pull the error as it occurs, instead of the after error messages.
It doesn't matter. The logcat is just a log file that covers a specific time period (or rather size... it's limited to something like 465 KB). It's constantly being updated so pulling it right after the error will get the same log as starting it and then getting the error and then stopping it.
I get the same problem as with WiFi Tether (which I should have described before.) The problem is that after the wifi tether (or barnacle) turns on (or enabled), the SSID does not appear on the client device's wifi list to connect to. Specifically with Barnacle (I had to check the "Skip wpa_supplicant" box) the console says:
Starting...
Data network is ready
.ini file prepared
WIFI: driver loaded
Connected to NAT
Runnings...
but the SSID never shows up on the client device (either after scanning wireless networks or using WIFI Analyzer. Any idea?
Wifi tether or barnacle won't work for me either. I've gave up on even asking cause someone says "use xxx app, works for me" or "why would you want to tether with virgin it's so slow". Slow speed is better than no speed. If you find anything that works please share. If i come accross anything I'll let you know :beer:
Would Foxfi work
I would try but I'm stuck on 100% stock until I can get an avalible computer
Sent from my VM670 using Android Central Forums
I am using this ROM, and Barnacle works fine for me after disabling the wpa_supplicant setting. I wish I had more information for you. Not sure if it works with this ROM, but you can also try Foxfi.
Abheetha Athukorala
