[ROM][WIP]CM9.1.0-BobZ
installed and everything looks great. speaker phone is VERY LOW. any fix for that? also is there a way to get music controls on lock screen without an application?
Sent from my VM670 using Tapatalk 2
You mean like this?
Re: [ROM][WIP]CM9.0 RC0-BobZ
I Lovee This ROM Ive tried another ones.. and this ones runs perfectly fine but there is a problem with the audio on headphones... they sound MONO instead of STEREO idont know if you guys are experiencing that but its happening to me and the mic Too and theres alot of other mistakes but bob really rockss the ROMS so hell put it to Work :)
yes I see that now. works with Google music but not pandora.. not the worst.. thanks again
Yes...., and same here, the speaker phone is very low
Speaker phone has been a known issue since cm9 started just deal with it or go back to cm7 till this rom is fully functional it was released to be tested every rom for the v has barley hit beta bobzhome will try to fix it just give him time as for your phone try reinstalling the rom use Leslie's wipe zip and that should make it work
I got the headphone problem too. I have faith in bob he will come through
the one bug that was never figured out in the gb rooms was that if you listen to music though a cassette adapter and a call comes in the caller can not hear you unless you use speaker. in the froyo rooms you could just talk and listen through the speakers...any chance this could be figured out in ics?
either way I am enjoying this rom...thanks so much for all the work on it!
I'm not sure if this is what some people have meant by speaker, but when I'm talking on the phone I can barely hear... just saying, otherwise this is an amazing rom!! :)
Reactions: drm1992
Well I just experienced some unusual I got all my messages from earlier till this time: D this is shocking I thought people forgot bout me
cant download google maps for navigation keep getting package invalid any reason why, by the way this rom rocks
This usually indicates you are out of space on your data or cache partition. Do you have an sd-ext partition, and is it being used?
I don't know if anyone else is having this problem but I cannot scan barcodes or QR codes on this rom or Quattrimus. I can see the camera auto-focusing on it, but it won't scan it.
Thanks!!
Here is an issue, anyone else have it??
1 - use browser and I just get a white page, click the button that shows bookmark button (makes browser page smaller) I can see the page I am on...
2 - I use xscope browser. open it up and ONLY get a white page????
Thanks
Nice ROM Bob.. Been running it for a few days and no reboots at all,
Like this one a lot. Great job..
Reactions: BobZhome
Thanks!!
Thanks
I'm on quattrimus but I had a similar issue to this with Facebook. Try forcing gpu rendering under developer options... Might not work but it did for me.
This did fix my issue. THANKS!!!
MisterVoltio
