[ROM][WIP]CM9.1.0-BobZ
I really like this rom ....... but idk, I can't download apps
y os data is maxed out, and sd-ext is maxed out and can not download apps no space, but only with this rom. On phone any fix?????? I'd really like to use this rom
Re: [ROM][WIP]CM9.0 RC0-BobZ
Bug Report. The time on the lock screen is right but when unlocked the time in the upper right hand side will at times not update (has been off 30 minutes before) and text messages will not pop up in notifications. Tried a wipe and reinstall, same issue.
Reactions: glarepate
I had the time issues too, but my sense time widget was always right so I just used that, and my messages were starting to not pop up today either or make a noise/vibrate... not sure why
Try doing a full wipe and then reflash the rom. That should clear your data issues.
The time problem is a known issue with ICS CM9.
Any reason battery wouldn't charge
Try rebooting. Also make sure you wiped before flashing.
I see on the OP its still listing bt calling not working. Is this still the case? I know tdm got it finally is the only reason I ask ...
I like testing roms out, but I can't without that working ...
someone posted links to apps that would help with the volume issue.. can't find that post now??
Sent from my VM670 using Tapatalk 2
Nevermind. I found it and it did not work with the free versions
I am not trying to complaint, just wanted to report that I am also getting the conflict with the time not updating, and I had the issue with the white screen when browsing the internet, going on face book, and trying to read my mail from gmail
Other than that its working well though.
Reactions: BobZhome
to fix the white screen issue, I actually had to go to Developer Options and disable "Force GPU rendering" .. trying toggling this setting.
That's funny, I had to enable that setting on quattrimus to fix the white screen issue..... O.o
BUG: backlight on keys don't go out when phone is locked.
Does it work with cannibal? Or do I have to delete assert script myself? :)
To make this work with other recoveries:
In the rom go to /meta-inf/com/google/android/updater-script open it with notepad and delete everything before the first semi-colon and also the first semicolon. After that save and repackage into rom.....if using winrar/7zip a prompt will ask if you want to update the zip, press yes, if using windows explorer to open the zip, go get 7zip or winrar....
Sent from VM670 on MetroPCS
I can't remember if this is possible, but since it's the same rom, can I just wipe Dalvik/Cache and just install on top of the current installation or do I HAVE to data wipe also? Either way, I'll be doing this when I get home from work, but I'd like to know my options.
byhuj52
