Re: [ROM][WIP] Unofficial CM7 (Gingerbread) - 7/9/2011
Use a clean tree with the stock binary blobs.
On 2.2 froyo on all phones there is an issue where the status bar signal icon basically over exaggerates the signal strength. For example it may show that you have four bars when you really have two.
Also I resigned and zipaligned the .apk's in my build and some how the camera works now.
I recompiled the build using different vendor proprietary files and omitting the cnd from the thunderc_device.mk
Next test in about two hours. Maybe something will change. If that doesn't work I'll have to try changing something with the build environment. Maybe I'm getting bad builds because I'm using wrong gcc version or something.
Sent from my Optimus V using Tapatalk
