ARCHIVED: [ROM][WIP] Unofficial CM7 (Gingerbread) - 8/19/2011
Status
Not open for further replies.
Can the smartass governer be added to the kernal or should I just flash a different one that has it already?
Re: [ROM][WIP] Unofficial CM7 (Gingerbread) - 7/9/2011
my experience, bluetooth streaming audio works (havent triedbt calls), calls work, speakerphone works but volume control is a bit finicky as previously reported. wireless tether works. sync works.
this rom is amazing!
Yes. Use the built-in CM7 tether app.
I promise I dont see a CM7 tether app at all! Where is it? This is nothing like the Evo. I'm trying to get this going on my wifes Optimus S so she can tether to her tablet. Nothing seem to work. What gives? Any help is appreciated.
Nevermind I just found it in the regular wireless settings. Thanks anyway.
Does ADW Launcher have an option to make the app drawer background solid black instead of transparent? I tried looking through the settings and I couldn't find anything.
Did you get it compiled without hacking it up?
Well I'm currently running my alpha build (v0.1a5) The only bug I have with my build now is the default language in the settings is set to Md instead of English. I compiled a sixth alpha build (v0.1a6) using the last post of instructions you gave me about lunch and make ota instead of brunch, but I haven't had time to test it yet.
In short the language bug is the only bug that's not in ath3nos download.
I am having an issue with the individual ringtones, (the ones you assign to contacts) had the same problem with zefie's... It always plays the default system ringtone. Every once in a while it will play the ringtone i have selected but the very next call it reverts back to the default system ringtone.
Sent from my Optimus S using tapatalk.
What is the smartass governer?
its similar to interactive, but rewrote in some way to make it alittle better, i've never really found a good answer, i have seen it give me alittle better life when i've used it, it also seems to give better performance right at screen on, a bit less laggy...
I'm on an Optimus V and haven't had time to switch over to this ROM from aospCM7. But if the Bluetooth issues are exactly the same between the ROMs, this is what I experience on aosp:
Working:
1. Bluetooth file transfer works.
2. Bluetooth audio output works (e.g., BT stereo).
3. Voice Dialer works with Bluetooth (both incoming and outgoing audio).
Bugs:
1. The other party can't hear me during a call, but I can hear them.
2. The phone forgets all Bluetooth devices after a reboot, so that I have to pair them again.
Hopefully I can get this ROM (or better yet, my own compiled build of blarf's source) flashed later in the week to test this stuff directly.
For the s series no audio or mic comes thru on any calls incoming or out going on any of the cm7 roms I have tested tried to reboot and it remembered my device with this rom never tried rebooting
The other roms
Status
heritagevine08
