ARCHIVED: [ROM][WIP] Unofficial CM7 (Gingerbread) - 8/19/2011
Status
Not open for further replies.
OK sweet. Umm can i use the picasticks kernel that I have installed? Will it work with cyanogenmod?
Re: [ROM][WIP] Unofficial CM7 (Gingerbread) - 7/9/2011
You would need to flash it after installing this if I understand correctly. I would recommend using xionia though. Its more compatible.
You can flash picasticks, but that kernel is not really designed for gingerbread. I have run it on this rom, but IMO it was a little slower and I also experienced reboots at lower clock speeds than the built on kernel.
Sent from my LG-LS670 using Tapatalk
I'm running picasticks at 825mhz/320mhz with no problems at all. My phone seems a little more stable than with xionia.
sent from my CM7 Optimus
I found these notes in languages_full.mk at ~/build/target/product.
# This is a build configuration that just contains a list of languages.
# It helps in situations where languages must come first in the list,
# mostly because screen densities interfere with the list of locales and
# the system misbehaves when a density is the first locale.
"...mostly because screen densities interfere with the list of locales and
the system misbehaves when a density is the first locale."
That completely explains the issue's cause.
Issue 395 - cyanogenmod4milestone - wrong build.prop settings? - Issue tracker for Milestone CyanogenMod port - Google Project Hosting
A google search brought me to this conclusion.
Why wouldn't google just create something like "ro.product.resolution.class=mdpi"?
Sometimes when moving an application from the phone to SD it says "Failed to move application" however pressing the move to SD button a second time moves the application without any problems. Anyone else getting this?
I'm using data2ext, so, no. No need to move something from sdext to sdcard lol. Not sure on your issue but I have never seen it before even when I didn't run data2ext ....
I had this issue too, but it was on a different rom. So its not this rom specifically. I think its just a timing issue. If you wait another 30 seconds before clicking the button do you still get the error.
I have been using a2sd for a while now so I don't have to use the process you are following.
Should have an update later today. Compiling right now. Of course I always flash it and test stuff out before I post it, but it will be today unless I screw something up.
Check camera, Bluetooth and any other feature we like to use please! XDXD
Sent from my Optimus V
I don't use BT, so that one will need to be tested after I post it.
You have to sometimes click twice on an app you want to move. I have this problem now and when I was stock. All I can say is I have about 41 apps on the SD card that work perfectly fine,6 apps on the internal that say cannot be moved,and 6 that say can be but do not operate correctly when moved to sdcard. You can move any app using titanium backup but IMO apps to SD is the best bet to tell if an app will still operate correctly.
Might be too late to say this...but when using a computer to "install" an app OTA from market.android.com, it never sends it to the phone.
Hmmmm...I'll look into it and see if I get the same thing. Anyone else have the issue?
i just came from reborn 2.2.2, how does the battery life of cm7 compare?
Status
Yageornba
