ARCHIVED: [ROM][WIP] Unofficial CM7 (Gingerbread) - 8/19/2011
Status
Not open for further replies.
Re: [ROM][WIP] Unofficial CM7 (Gingerbread) - 7/15/2011
MMS is not currently working for me with the 7/15/11 release but strangely enough it did work on the 7/9/11.
Was it removed? Also will the fix be available hopefully in the near future?
Read two posts up.
You can try GO SMS PRO from the market and set MMS manually.
Just sent and received mms. When I originally flashed the 0715 I didn't clear data, system, or cache so maybe that's the difference?
What happened with the MMS stuff was that I intended to revert back to the stock CM apns-conf.xml after the Virgin Mobile USA changes were merged in. Unfortunately I ended up leaving it out. So. Copy the file from the CM7 repo, from a backup, etc. The next time ath3n0s has time for a build it should work out of the boxl
Cool, I'll wait for the update. Thanks
Somewhat unrelated to the topic at hand, but anyway... I tried desperately today to figure out how to move my dalvik-cache to sd-ext, and link it all up nicely. But apparently I can't figure out how to make the appropriate changes to the boot.img, or something like that. So it keeps thinking that dalvik-cache should be in the /cache folder, where it was originally moved to. Now this is better than it being in /data, as it gives us more room for apps, but the cache folder still isn't big enough for me (lol). And it's especially painful since you'll run out of space in the cache folder long before you run out of space in the data folder (at least when you install/move a good amount of apps to the sd card). That's why I've started trying to get it over on the sd card, on the sd-ext partition. It may be too much rediculousness to ask, but is there a way to remove the mod that moves the dalvik-cache to the cache folder, so that I can follow any other guide out there to move it then over to sd? This is the reason why none of my apps will update through the market, and why I can't download hardly any new apps. I know, I have a slight app addiction problem.. But that's beside the point. Any thoughts??
Edit: I should note that I've tried creating a symlink at /cache/dalvik-cache/ that points to /sd-ext/dalvik-cache, but that didn't work at all. Maybe the sd card has tyo be mounted earlier in the book for something like that to happen? I'm really just spitting out random words, so who knows..
Living this ROM, but there are a few annoying issues. First is that my mms isn't working. Second is that it takes 4-5 seconds for my screen to rotate. And thirdly is that if I turn the volume almost all the way down while I'm using the phone it mutes the other person. And the level just before mute is pretty loud.
Is there anyway for me to fix these issues? I'm on Sprint btw.
See a couple of posts back for a flashable zip to fix mms. Can't help you with your other issues though. Hope this helps.
Sent from my LG-LS670 using Tapatalk
Ok, I'm glad I'm not the only one having the delayed rotation of the screen. I thought maybe my phone was just malfunctioning.
I absolutely love this ROM, but hopefully we can get a fix for that in the near future. =)
I don't often ask for a request in ROMs but in this case, is there any way to update the music.apk to the new Google music apk so when I flash the ROM the app is the new google app and not the music mod app
I know I can download myself (which I do) but it just looks weird that I have I currently have two music apps.
yeah im not as big of a fan of launcher pro as some of you. if i was to use different one it would be go launcher but i was just wondering if anyone else was having these problems. someone? anyone? adw crapping out? disappearing dock? changing icons? anyone?
I was having some of the same issues with ADW both the included version and the free market version. ADW would randomly FC or the dock would disappear. I've never had the changing icons issue at all and I never had any of these issues when I was running ADW as my home app on the stock Froyo ROM.
Also, I second this particular request. I don't need two different Google Music Apps on my phone after all.
I love this ROM too. I've had the delayed rotation problem on every CM7 version for the Optimus S. It works great for a couple of days and then the delay builds. Sometimes if I clear the cache it helps, but it's very temporary.
I'm curious if this is something that has any sort of easy/doable answer since it seems like a common issue in more than just this 2.3 ROM.
I second that the rotation lag seems to be a cm7 issue, not just this rom. I wonder if the other optimus lines have the same issue.
my screenshots taken with CM7's built-in screenshot utility are coming out upside down, even after a hard reset... anyone else experiencing this?
yes, now that you mentioned it, I also get my screenshots upside down.
Status
dftyuc
