ARCHIVED: [ROM][WIP] Unofficial CM7 (Gingerbread) - 8/19/2011
Status
Not open for further replies.
Re: [ROM][WIP] Unofficial CM7 (Gingerbread) - 7/15/2011
my screenshots taken with CM7's built-in screenshot utility are coming out upside down, even after a hard reset... anyone else experiencing this?
Mine too, I never had a screenshot program. So I assumed that's what happens. Silly Me.:p
yes, now that you mentioned it, I also get my screenshots upside down.
this didn't happen before, probably on the last version
guess i don't take screenshots enough to know for sure
Everday I wish more and more we could get a CM7 port that has MMS/Wifi/AP Tether/ with working Camera (nn Bluetooth) w/o Audio issues, I'm STILL torn between this and Scott Pilgrims, ugh decisions, decisons...
Ok so all of a sudden I get a pop up on my screen an I can't touch it will read a number then :upd=0/0 an I don't know what it is. Can anyone help?
I came from SP CM7 to this one. And for the best. This one plays AAC music, SP doesn't. Only problem I had with SP was AAC... :)
I'm having an issue with my wired headset. Volumes on speaker mode or while not using the headset are fine, but for some reason using the headset the volume is really low (for the headphones not the mic). I had this same issue with the SP CM7 rom but it also affected speaker mode, and the mic didn't work at all on my headset. I hope this can be fixed in a later update, I prefer this rom to all and have been using it as a permanent rom.
All of the things you have listed work on my Optimus S with this ROM...
Here's what I suggest:
1. Download the 7/9/2011 build of this ROM, clear all system, cache, etc..., flash ROM, flash gapps, boot.
2. Download the 7/15/2011 build of this ROM, DON'T clear any data, cache, etc... flash ROM, flash new gapps, boot.
Then everything will work as I've stated. Good luck.
Reactions: anim4l
I love this rom. Unfortunately I can't iron out all the issues Im having. Ok really just one issue mms. Even after flashing apns-conf.zip. Guess I'll nand back to reborn for now. Pity did I mention I really love this rom?
Here is your answer (the post directly before your last post):
Reactions: PrimeOne1
Have you tried GO SMS Pro? I have used it with GREAT success, you can manually program APN (just need the URL set, maybe port set to 80 (I did) and it started sending just fine)
What seems to be the problem with your MMS? Receiving or sending?
I havent looked too hard but I dont have the build from 7/9 :-\
I will give this a shot I've been trying to send to myself to no avail. Not sure if I can receive but ill let you know how i make out.
Those of you who don't like having two music apps, just uninstall the old one through titanium. It doesn't mess anything up.
Reactions: CardcaptorRLH85
Ok, so, at the risk of sounding like a noob...lol. Does anyone else have the issue when they boot the phone up, that it says you have a voicemail and will repeat the voicemail alert indefinitely until you turn it off? I've always had this on CM ROMs so I was just wondering, is it just me, or is there a fix?
Go to Settings->Call Settings and uncheck Voicemail notifications. Then follow the directions from here using Method II (2) and you'll have Sprint VVM (Visual Voicemail) back and running.
You will begin to get texts from the number 9016 after doing this, simply disable notifications from the stock messaging app, and install a third-party messaging app such as Handcent and add the number 9016 to the blacklist.
Reactions: anim4l
Could I get the links to those? I can only seem to find the latest ones
It works. Great app! I hate to sound fussy but I'd rather be able to use the stock messenger app. Weird I know I also hate google voice.
After much work and a lot of headaches I have finally managed to compile some code. This is a work in progress and by no means complete. That means not everything is working. I will try my best to keep this up, but keep in mind that I do not get a whole lot of time to work on it and I will not be able to do nightly builds. I will have updates when available. Most of those updates may be simple CM syncing and others may have fixes to any bugs we identify. With that being said:
Credits:
CyanogenMod Team - does anything else need to be said?
blarf of CyanogenMod Forums - for helping with compile errors
zefie - for his original work on CM7 port for the OS
mik_os - because he started it all
aosp - for moral support.
Source:
https://github.com/inferiorhumanorgans
Hey... Now that's what I'm talk'n about!!! AWESOME!
Spent the last 2 days root'n & toot'n...My first (broke dat cherry)...
BIG thanks to ath3nos and ALL for the work you all put into these things.
I was a little intimidated before I started but with the the help of the players here... It turned out to be a very easy process.
Flash took less than 5 minutes!
THANKS AGAIN GUYZ!! :)
Status
fix my speaker
