ARCHIVED: [ROM][WIP] Unofficial CM7 (Gingerbread) - 8/19/2011
Status
Not open for further replies.
Re: USB Host
Hmmm, interesting... I have a CarPC on my RX8 (using microtech) wonder if I can connect a USB-to-Serial and connect it to this phone...
Thats what i'm trying to achieve. I have the Tuning Software loaded and running but no usb for my serial connection :(
Seems like these guys are very close to making it work on the Optimus One.
Optimus One support USB host mode? (update: working now!) - Page 7 - xda-developers
Its directly supported on 3.1 already and backported to 2.3.4 (API Level 10)
http://developer.android.com/guide/topics/usb/index.html
Re: [ROM][WIP] Unofficial CM7 (Gingerbread) - 7/15/2011
Ok so lately IV be getting the box piping up saying 400: UPD = 0/∅ but the number is all was different. Can some help me get rid of it. Pls
My headphone out isn't working. Am i missing something? I did a search of the thread, but didn't find a solution.
If I use AudioGalaxy, it stops playback when I remove the headphones, so it knows that they are there, but audio doesn't come through the headphones, it continues to come through the speaker.
So far, other than some small glitchy things, this is the only problem I've had with this fine rom. I'd like to continue to use it, but headphones are pretty important, as I use my phone as a media player.
Thanks in advance!
EDIT : I should specify that these are wired earbuds, not bluetooth.
Thanks in advance!
My headphone out works, and yours is the first I've heard of this problem. You might want to check the headphones with something else, make sure that they work, and if they do, reflash the rom.
Ok, tried with several headsets, and the audio cable into my car stereo. All do the same. The little headphone icon even comes on in the notification area (just noticed that).
I'll try re-flashing and report back.
Thanks, though, for such a quick response!
Are there any other themes that can be used on this? I miss having 6 signal bars, the circle battery indicator, and a black background in messenger.
yes, use this:
[UPDATE 7-19-11] Theme Chooser Themes - Over 180 Themes! - New Format! - New Thread! - xda-developers
and if you want to add more to customize use this as well:
[Morphs] Theme Chooser Add-ons: Lockscreens, Dialers, Boot Animations, Wallpapers - xda-developers
I am currently using Blue Buzzer Theme with the theme chooser addons :Standard Addon Cyan & Cyan Dialer Numbers.
Re-flashing did it!
Thanks again for the advice!
No problem. For future reference, if you have any problems that nobody else is having, try a reflash. Usually fixes everything.
@everyone with screenshot bug :
What build are you using?
Using the 7/15 build with Apn fix for MMS I dont have this issue
More so to have a Cm7 port that is based off the OFFICIAL gingerbread specially baked for the optimus phones
I know the real reasons why. I'm not taking any credit away from this build though.
Status
PrinceVic
