ARCHIVED: [ROM][WIP] Unofficial CM7 (Gingerbread) - 8/19/2011
Status
Not open for further replies.
Re: [ROM][WIP] Unofficial CM7 (Gingerbread) - v0.2 - 7/4/2011
I can't seem to get the Sprint Visual Voicemail to work. I used Google Voice in the past and always problems with it. Not a top priority but thought I'd mention it.
workaround:
pull the apk for sprint's visual voicemail from system/app from a rom with it working (i.e. stock, reborn, etc) and use titanium backup to backup the app.
after flashing (or restoring) this rom, put the apk back in system/app, change the permissions, then reboot.
after it boots, load titanium backup and restore the visual voicemail data, then reboot again
now you should have functioning visual voicemail
Reactions: gizmosears
I have 1 bug to report after a day and a half of use. Every now and then, my lock screen will freakout, causing me to have to hit the power button and start over per say. Not a biggie for me, but want you to know nonetheless.
Please note : I am not a BT user of any kind someone I did not even look at it. Keep up the great work!
Sent from my CM7'd Optimus S.
Went ahead and tested it with my SK Earbuds, these are wired. Music and audio as others have said works fine. What I find odd about the call feature is that the mic works, I just can't hear anything as soon as the phone is initiated.
Yeah I flashed this ROM but sync isn't working for me.
Did you log into your google account from the market app? (stupid question but just making sure)
workaround:
Thank you. It worked fine.
Ok try this for me. Using titanium backup, wipe the data for gmail. Go into settings and accounts and tap on your gmail account and recheck sync gmail. Should fix it.
I tried sending myself an email and it did not come to the phone until I manually synced. Did steps above and resent email, and recevied it without manually syncing. Let me know if this does the trick
so I've been fiddling around with things trying to get everything configured to my liking. One thing I usually do is change the lcd density. Normally I would just go into the build.prop and edit it there, tried that though and the lcd density does not appear to be listed in the buid.prop. Am I looking in the wrong place, this is my first gingerbread or cm rom.
Interesting. I don't see it in the build.prop either. It should be there. Maybe that's why I thought everything looked bigger. It might default to something other than 160. I will make sure to add it in the next release. You could manually add the line you normally edit, reboot and see what happens.
Sent from my LG-LS670 using Tapatalk
Aye that's what I was going to try just wanted to make sure I wasn't missing something obvious first. Sadly that doesn't appear to be working for me, not sure why. I'm not extremely worried though as long as it's sorted in the future I'm happy.
I do have a small request; any chance at getting an ad-blocked host file in the future releases, save me the effort of swapping it out myself :D
Theme chooser if definitely missed, but I'm sure out will make a quick return
What about theme Chooser?
Theme Chooser and other features will be coming soon. I want to work out some of the current bugs first before I start adding a bunch of stuff to it. Adding stuff without fixing existing problems can make it harder to track things down. I'm finally back to work, so I have time now to work on stuff, lol.
do you not like ADW launcher? so fare so good still play'n sweet skype works:D
Compiling again. Hopefully will have a few of the phone/speaker phone issues resolved (crossing fingers). It takes about 3 hours to compile on my machine. Then I test it a bit before I release it.
If it seems to work out I will let you know. And of course I always hope that I won't break anything else that is already working, lol. ;)
Reactions: jasenr
Status
lefler
