ARCHIVED: [ROM][WIP] Unofficial CM7 (Gingerbread) - 8/19/2011
Status
Not open for further replies.
Re: [ROM][WIP] Unofficial CM7 (Gingerbread) - v0.2 - 7/4/2011
do you not like ADW launcher? so fare so good still play'n sweet skype works:D
I'm not a huge fan of ADW, but that's just me. I also figure that it is available in the market for anyone who wants it. So, I may strip it out. I haven't decided yet.
I wouldgo with stock launcher. People can always get ADW, Launcher PRO, GO Launcher, etc. from the Market.
Super excited about this. Just logged on because I was gonna switch back to the latest Scott Pilgrim, but then I saw this. I'll test it out all day while I'm at work, and report any bugs I find when I get home tonight.
adw launcher is personally my favorite launcher i would keep it
Mediafire doesn't work to well in the android browser. i don't know if that is where the link is going though.
I like the rom build though awesome stuff :D
Side question though is it better to leave the wifi on when the screen goes off or use the default setting cause with my old pre using the wifi all the time saved a lot of battery idk if that is true with our phone though.
Note on the adw launcher if you use the honeycomb theme its much better :D just my two cents.
The gmail thing its happened to me on all the cm7 roms ive tried you need to go to accounts and manually select sync.
One bug to report though when i first started the rom up after flashing it, it was in german...
German???? Never had that happen to me. Anyone else get this?
I will try to start hosting the Rom on my dropbox. I am limited at work to what I can get to. Mediafire is one that I can, but not dropbox. I'll see what I can do. Might even try to find somewhere else to host the downloads.
I agree but no disrespect but I my self bought the adw launcher from market so.with rom now it seems useless
So, if I pulled out ADW then you would be able to get your money's worth?
my phone does do weird stuff it crashed when i used flash in the web browser and when it rebooted the battery started counting upwards from 5% i did another reboot and it went back to normal...though one too many hits to the concrete could do that.
*edit if anyone wants basic flash http://forum.androidcentral.com/sprint-optimus-s/100266-working-non-adobe-flash-player.html
you should keep adw launcher in the rom
Oh like what kind of changes?
You would need to remap the keys since the home and menu keys are reversed between the 2 phones. Also, you would need to edit the apns-config.xml and the eri.xml files so that it says Virgin Mobile instead of Sprint and along with apns-config.xml you would need to modify the mms.apk so that picture mail would work. Check out the thread (can't remember the name) that has flashable zips for our OS to use aospCMod. You should be able to look at those for examples of what needs to be changed to get it working properly on the OV.
yes because then.theres no.point of the app dev getting money out of it,if u guy can put it on a rom that doesnt make sense to have an app for it on the market when u guys can do that
Status
lefler
