[ROM][ZVJ] 2.3.3 DanteRom v4 [UPDATE] 10/14/2012
This not an issue I EVER noticed. Can anyone else verify? I was gonna upload a new build today, but I dont want to if it is all messed up to start with.
I found out what was causing it if you don't do a full wipe while flashing the privacy mod the Bluetooth toggle stops working if you then revert back to the original without wiping the gps toggle stops working too so there's nothing wrong with the Rom its just the privacy mod screwing something up
Sent from my Opti s running DanteRom once again :)
Reactions: hlxanthus
Re: [ROM][ZVJ] 2.3.3 DanteRom v2.3 [UPDATE] 07/01/2012
Awesome! This was driving me nuts as I couldnt figure this out LOL When I upload I will give explicit instructions! When you flashed, did you wipe anything the first time? I usually recommend cache/dalvik cache at the least.
Yep wiped cache and dalvik cache like you said in the first privacy mod test but no dice it has to be a full wipe
Re: [ROM][ZVJ] 2.3.3 DanteRom v2.5 [UPDATE] 08/12/2012
DanteRom Updates
v2.5 Updates +Settings Menu modified to remove "Privacy>Factory Reset" as an option due to brick dangers. +New Boot Animation added. This is an animation that I have modded from the AOSP 2.3 bootanimation.zip. Please give feedback!
Instructions:
-Download DanteRom.v2.5.signed.zip [MIRROR]place on the root of the SD card
-Boot to Recovery, Cannibal Open Touch recommended but Xionia is still okay. (power down, then press Home, Vol Down, and Power and hold to the first LG splash)
-Create a nandroid backup, this is a must.
-Perform a full wipe, I use Debug-FormatALL.zip if on Xionia for simplicity. Seems Zefie's link is down so I uploaded it.(Zefie's page with the debug zips)
-Disable Signature Verification and (now signed!) Flash the zip file.
-Reboot and Enjoy!
________________________________________________​
Kernel: (optional, but recommened)
-Please install Rom and boot into the rom first. Then download the kernal of your choice and place on the SD card. Boot into recover and flash, no need to perform any wipes
-drewwalton19216801's HydroKernal GB is my recommendation found here!
ATTENTION When switching to Dante.Rom.v2.5.signed.zip from you MUST perform a full wipe. Not doing so breaks functions within the QuickPanel Mod, and maybe others. Do NOT report any issues if you have not.
Gentlemen, pardon my ignorance but I must ask. How does one update a ROM such as this? I already have version 2.3.3 installed and working properly, so should I simply use the "install zip from sdcard" in Xionia (after placing the 2.5 zip on there of course), or am I supposed to treat it as a completely new installation, which includes doing a full wipe? I would like to be able to keep all my settings and apps intact if possible.
Thank you!
Thank you!
As he says a full wipe is required, you should clear data via xionia (switch to COT!) Before flashing. To avoid losing data, try using titanium (DO NOT BACKUP SYSTEM APPS THOUGH!)
Something in the settings mod requires a fresh install or it breaks some of the quick panel toggles. You can successfully use titanium backup to backup and restore apps and data but just use it for apps from the market NOT system apps.
Sent from my Nexus S 4G using Tapatalk 2
DanteRom and HydroKernal flashed 3 days and running VERY smooth. So far, everything is working and no FC issues.
Awesum ROM.
Rom is working great, however I can't seem to get the Dalvik2cache mod to work. I have tried a method mentioned of updating it, but that didn't seem to fix the issue either. Any suggestions would be most grateful.
That should work by default. What exactly is the problem? Are you having market issues?
Two issues I'm having. First, stock browser wouldn't let me download to my phone, kept saying download unsuccessful. Switched to the dolphin browser and all is well.
Second, I seem to be stuck with the wrong time zone stamped on my backups. Not a big deal, but is there a fix?
Sent from my LS670
OK. Using COT recovery and HydroKernel. Would my issue be with either?
Thanks
Sent from my LS670
Stock browser has issues DLing from some sites. Try enabling desktop mode
Reactions: jteee
(Cough Cough.....Mediafire....Cough Cough)
Issue was I wasn't able to download roms and such from your DropBox when I clicked the link. Wasn't aware of a desktop mode.
Dolphin is working pretty well for me now.
Hmm....might have screwed myself but, is there anything I can do if I cleared the phone via privacy? I didn't realize I shouldnt do that and now I cant get any of my backups to restore. It just reboots back to recovery. TIA
Stephen
EDIT: NVM, I found out that I did in fact brick it but am going to try and fix it via:
http://forums.androidcentral.com/lg...-phone-via-menu-privacy-after-custom-rec.html
What recovery are you on? Xionia and COT I believe have a fix boot loop option. Also try restoring a rom and then perform a factory reset from recovery.
Reactions: StephenAaron
Ayomide
