[ROM][ZVJ] 2.3.3 DanteRom v4 [UPDATE] 10/14/2012
Re: [ROM][ZVJ] 2.3.3 DanteRom v2 [UPDATE] 05/08/20012
Just flashed this rom, but Gmail isn't working at all...any ideas?
nm, got it working. sry.
On my end, I am running v2 with the above framework mod. Just powered on my phone and got gmail notices. Was able to send and receive from the app. In what way isnt it working? Was this from a clean install?
Just saw you got it working, no big deal. Did you have to do anything special to get it running? If you did I will post a note in the OP. Seeing as you are the only one has posted recently about my rom, do you have any thoughts? Did you flash the newest mod? Any noticable difference?
I guess I was just impatient. I cleared data, and then waited for sync to be done, and everything works fine.
I like the rom a lot. I tried gingerRom, but didn't really like it. Still can't figure out why turn by turn navigation doesn't work though. Just tells me searching for GPS. I get a directions list which is usually just fine, but would like to know what's up...
Did you update Maps via the Play Store?
You could also try this http://forums.androidcentral.com/lg...168060-mod-gps-fix-v3-4-21-a.html#post1713719
Edit: Okay, tested this a little more. Make sure you first update from the market. Then go to system settings>location & security and check use wireless networks. Navigation did work for me after that.
I will edit the OP with these directions.
Reactions: heathspawn
Re: [ROM][ZVJ] 2.3.3 DanteRom v2.1 [UPDATE] 05/11/2012
Another quick update.
v2.1 Updates
+Updated all apps. Now with a clean install there is 155mb free.
+CRT screen off animation now included.
+Install apps from unknown sources now enable by default.
+Media volume now moves in smaller steps with the volume rocker, 30 instead of 15
+Mod to allow smoother scroll within some apps
Links in the OP of course. If you are coming from v2, you can get by with only a wipe of cache, but you will not get the extra internal storage space. To get that, a full wipe is needed. All other changes will work just fine. As always, nand first then flash!
Dante.Rom.v2.1.signed.zip
Link2sd won't work with this rom... any ideas??
Rom is fast & responsive. Great work OP!
Sent from my cm_tenderloin using Tapatalk
I have never run such mods, so I didnt build it in. I would install 40+ apps with out it, including hbogo and netflix (big apps) without it. Yeah, I would have to move many to SD with the buildin app transfer feature of android. I will look into what needs to be done in the rom groundwork to support user mods, but it will never be supported natively by this rom.
If someone wants to set up and handle that let me know though.
Been running Dante for about 5 days now. Noticed that when someone calls me, the screen does not turn on automatically to identify who is calling. I have to hit the power button to see it.
Is there something I need to do to make this work?
Did you flash hydro kernel? I believe that is due to stock sprint kernel.
Try this. Make sure you have the latest version of my rom on your sdcard, download hydro kernel gb version as well. Boot to recovery, wipe cache, and under advanced choose format system (do not perform a factory reset/wipe data). Then flash the rom, then the kernel (you have to turn off signature verification for that) and reboot. That should keep your user data intact. Let me know if that helps!
Another thing you can try is to format the SD card. Connect the phone to the PC, backup all data on the sdcard to the PC. Open up your start menu open computer. You should see your optimus s there. Right click and open properties. You should see an option to format drive there somewhere. Sorry, not in front of my PC at the moment. You want to do a full format to fat32. Don't know why this helps, but there have been some reports on hydrorom of this helping with the wake delay issue.
Sent from my Nexus S 4G using Tapatalk 2
Thanks for reply hlxanthus.
I checked my sd card to make sure no issues there & none. Had 2nd Ext2 1gb partition I used for link2sd, erased & created Fat32 1gb partition. Still getting mount: invalid argument.
Every ROM I have used for this phone has allowed me to use link2sd but not this one...
My storage space thru titanium are:
System ROM: 166Mb (25.0 Mb Free)
Internal: 172Mb (20.2 Mb Free)
SD: 7.23Gb (4.21 Gb Free)
Thanks
I got Link2SD working!! Repartitioned Fat32 1Gb & Set as Primary.
Thanks Again for info & Very Responsive ROM :)
Reactions: hlxanthus
Thanks
Would you mind doing a more "guide" like post on getting that working? That way I can link to it in the OP for those wanting to use this mod.
Using Link2SD with DanteRom v2.1
I had "Cannot Mount: Invaild Arguement" using a 1Gb Ext2 Partition
Using MiniTool? Partition Wizard I "Deleted" my 1GB Ext2 Partition & "Created" another 1Gb FAT32 Partition & Set it as "Primary"
Lind2SD back working again!!
Hope this helps.
Re: [ROM][ZVJ] 2.3.3 DanteRom v2.2.1 [UPDATE] 05/19/2012
Battery bar MOD is really cool. Surely makes this ROM stand out. Now to figure out how to hide the actual battery icon and I'm golden....:p
As I understand it, to completely hide it causes some battery bar malfunctions, but I am planning on retheming the current battery to have just the percentage.
Reactions: aaronrw
This isn't really a bug, but it looks weird. At the top of the screen there is a thin white line and it sticks out. Anything I can do to remove that line?
LOL thats the battery bar silly...new MOD
byronsss
