Beautiful ROM everything works (no FC's or anything). Well done indeed.
However I have noticed that the keyboard typing sound is practically non existent.
I have all the sound setting turned all the way up, stock 2.3.3 is MUCH louder, am I missing something / any way to fix this?
I've downloaded / installed a few apps, when I try to slide / swipe the notification off the dropdown menu it force closes. is this a known bug/problem?
Wow, thank you so much, I can hardly wait, for now I'll live with using the clear button (which works fine).![]()
This may not be related but while downloading/installing an app the screen timed out and wouldn't restart, a quick battery pull fixed it though.
I then opened browser to set my homepage/settings and it force closed but then seemed fine after that.
I'm not trying to nit pick just offer (hopefully) the "type" of feedback you're looking for. :-[
P.S. I'm NOT running amphetamines at the moment just your ROM and Hydro kernel.
I would love to comeback to this rom, but i really love the T9 typing feature of the HTC_IME mod in Hydro Rom. Anyway of implementing this into Dante Rom?
As a further note, this goes out to the community as a whole. This is a project that I have put alot of thought, research and effort into. I would like to do more, but i am not getting alot of feedback. In part that is a good thing, as most people only mention when there are problems. But it also leaves no reason for me to keep getting my hands dirty on this rom. I have more or less accomplished all my major goals and produced the very rom I want to be using (even though I have moved on to another phone as my daily use, and the Optimus is only a dev device now). So everyone keep the feedback and bug reports coming in.
Is the keyboard compatible with other ROMs? I installed both clicker.apk and htc_IMEmod.apk on CAI and am getting some major FC-adge.
