[ROM][ZVJ] 2.3.3 DanteRom v4 [UPDATE] 10/14/2012
Re: [ROM][ZVJ] 2.3.3 DanteRom v2.2.1 [UPDATE] 05/19/2012
I would like to note an issue with my camera while running danterom, i initiated the camera app and noted some black lines across my screen while camera running, i took a photo and saw no black lines across the picture taken. I flashed gingerom afterward and no black lines.
fixed just started from scratch
thanks, unfortunately Cold as Ice doesn't seem to get along well.
The black lines are on my video recording screen and when opening youporn streaming vids :-)
Thanks for the ROM, just installed it over the weekend. Very nicely polished ans so far very stable. How hard would it be to remove Swype from the ROM? The version from the stock Sprint ROM is old and the newer versions of Swype beta can be downloaded from Swype | Text Input for Screens but will not install over an OEM package.
Very easy actually.
ATTENTION
Who uses swype? Those that do, would you rather have it removed from the rom so you can install the newer version?
Sent from my Nexus S 4G using Tapatalk 2
The older version works fine for me, and I like that it's included with the rom.
Maybe some want to keep Swype in the ROM, but I couldn't live with the old version, so I used System ROM Toolbox (free app, needs root) to delete the Swype package. Then installed the newest one directly from Swype. So there's a solution for those who want the newer version.
I just restored the newer version via Titanium Backup.
Quick question....
Will GB themes work on this ROM (without issue)? I really liked the "reTouched-GB" theme that I used on my last ROM and would love to use it on your ROM....
Thanks for making such a great, stable ZVJ-ROM!!!
Quick question....
As of right now there no themes compatable with Dante rom.
Ok, thanks for the info on themes. One more question....
Will the "mod_no-buttons-wake-GB.zip" that is an add-on for HydroROM work on this ROM, as well? I just realized that (unlike my ZVD rom) the four front-facing buttons will bring up the lock screen (from sleep mode) and I'd like to disable that, so it's only the power button brings it out of sleep.
Thanks for your help! :D
Sorry to ask another question, but is anyone else having issues with GPS navigation in Maps?
The only way Google Maps will locate me is if I enable Wireless Networks (which I don't want to do, for privacy reasons--I think Google knows too much about us already ;)). Once I uncheck Wireless Networks (even while still having GPS enabled), Google Maps says it can't find my location. Is this a issue with the ROM that it can't find location via GPS only?
Note: I updated Google Maps before testing this, so I'm on the current version.
** Update **
I was able to fix the issue by installing the GPS fix V3 posted in another thread. Big thanks to Buddlespit for the fix!!!
To install:
1. Download .zip file to root of SD card.
2. Boot into recovery and choose 'install zip from sd card'
3. Select 'choose zip from sd card'
3. Select 'gps-fix.v3_signed.zip'
4. Select 'yes' on next screen.
5. Hit back arrow until main menu and select 'reboot system now'
Enjoy!
This fixed my issue (and also holds last known GPS location, so it will work indoors, too). This is a great option for people who don't want to enable the 'wireless networks' location feature (since doing so means you also agree to share the location info with Google)
Just wanted to say thanks.
Issues encountered:
Human Stupidity: Didn't read stickies, unrooted ZVH, Updated to ZVJ. Had to roll back, re-root, then update.
Data connectivity issues: Could not connect to data. Flashed HydroKernGB, Updated profile/PRL, still couldn't connect. Reboot-Reboot-Reboot, no issues now(guess it needed to do it's boot maintenance).
Now, to fix that ugly as sin android boot logo. Thanks for putting the nice LG one in place of the sprint one for me. Saved me a flash/wipe/boot.
Now, FoxFi, I can't get to work. Went back to Wireless Tether for Root(still have the apk for it on cloud backup and hard backup on a flash at home).
All in all, lovin' this rom. Thanks, man!
Issues encountered:
I always rather liked the simple android boot animation, but to each their own. The sprint one always bugged me, hence why I replaced it.
I kinda pushed myself to get this rom up and running as my day job is slow in the winter and quite frantic in the summer. Hard to find the time right now to work on minor issues. The rom is very stable, so big changes will be slow to come over the next little bit.
As for foxfi, this phone is no longer activated for me so I cannot test, but worked flawless for me when I still had data to pull from. Does it no longer work for anyone?
It could have just been me on the FoxFi. I'm not used to it, so may not have set it up right.
It is VERY stable, and I love it. The launcher, the customizable dock, everything here is so much nicer than gROM I was running for so long.
So far, I don't see anything that needs fixing. It could just be me. Maybe dirty flashing it on top of itself would fix my connectivity issues? Could have been something as small as one bit not flashing proper on the radio. Stuff happens.
Five
