[Root] Epic 4G Froyo & Eclair ClockworkMod v3.0.2.5 Switch Between RFS & EXT4
Re: [Root] Epic 4G Froyo & Eclair ClockworkMod v3.0.2.5 Switch Be
thanks Paul. having an issue with current install of EG22 where my contacts icon has disappeared from the bottom of my desktop. Does this mean a bad install and I need to do it over again?
No I doubt it Ted.... Touchwiz and other launchers have all been famous for occasionally losing an icon or two on the launcher dock or homescreen... Could actually be part of the memory leak on GB but it happens even on stock OS too..
Usually you just put it back whenever it disappears or reboot and it comes back...
Need Help, phone won't boot up!
Need HELP!!
Ran the script and it worked perfect, but didn't reboot the phone.... I guess I read too quick and skipped over the part where it says "if it doesn't reboot your phone, run the script again."
I downloaded root checker and it confirmed root.
I attempted to reboot the phone, but now the phone just stays at the Samsung screen (the one with "SAMSUNG" then :: Mobile Exciting!! - Samsung Mobile :: underneath.
Phone won't boot up. I've done a couple battery pulls but nothing. I can't seem to get it to go into recovery either (which I understand is done by holding volume down, camera button, and power) Please help!!
--Ed
hehe... Ok.... should have searched first. Working on Odin restore, hope it works.
Followed the procedure exactly, but now my phone will not boot past the Samsung screen. Not even when I try to boot into CWM.
...help please
If you're having trouble getting your Epic 4g to show as a usb storage device try the following:
go to the phone dialer and type ##8778# and make sure both settings are on PDA. this will make sure you connect to the computer as a PDA device. try this before wasting money on a cable. the default if you have froyo is for it to be set as a modem... I know a guy that works for Sprint...
do i have 2 do gingerbreak or just oneclick root - i want the root so i can have wireless tether back on my phone .. also neway to get the messaging icon off my main bar on the bottom of my screen?
Just use the OneClickRoot and you can then enjoy wireless tethering.
Messaging Icon, you can swap out your launcher dock icons very easily. If I remember correctly go into your application list, press menu then you can drag and drop icons to your launcher dock or remove applications. (Its been a while since I've done this so bare with me if I'm not exactly correct on the sequence.)
stopwatch
