[Root] Samsung Epic 4G Official Froyo EC05 w/Optional EXT4
alright following up on comment #239 - i have syndicate frozen rom 1.1.0 - i restored all apps and data - even after u mentioned that might corrupt stuff...
fingers crossed i am up and running mostly to what i was with no issues what so ever... its fast as ever.... n everything works...
only think i miss is sprint navigation :( cos i used it extensively..... i found it better than google maps... anyways....
Sprint Navigation (Place on sdcard, click on it with any file explorer to install)
ClockworkMod 3
After you convert to ext4 can you still run the stock epic or do you have to switch over to a rom that supports it? I was just wondering....
Hey Guys so i was trying to get the email version of the app that wont ask me to setup a password: something like this to work - so they said first uninstall the email app... so i did.. and since then my phone's TW launcher keeps crashing as soon as it reboots - how do i fix this....
i am on - [ROM][ACS] SyndicateROM Frozen 1.1.0 (Takiya) :: EC05/1.3ghz/NoCheckboarding :: 3/27 - xda-developers ...
please help :(
please help :(
Try booting into CWM and wipe cache and dalvik cache 3x.
Program Monitor - app
I need a few stock apps that were on the epic which i loved.... please can someone help....
Friend and feed update
also how do we disable the exchange pin lock - i have seen a few thread with the the newer hacked version of the app - but cant figure out how to install and use em... please help..
thanks!
I followed "Procedure 2" and yes, my phone was on EC05, but I never got clockwork 3. I got the green text that had CW2.5 please help me.
Wow, I just realized I kept running the "run.bat" file from the rar "one.click.root.exploitv2.5.5"! Instead I was supposed to run the "run.bat" from "OneClickRootCWM3-EB13"
Sorry for the inconvient user error. It pays to pay closer attention. Again, sorry for being annoying. Anywho, yay I got my phone converted to EXT4. Thanks!
trying to root, but...
every single time i plug my phone into my laptop it says unrecognized device. could it be the wire im using? (the original one that came with the phone) ive tried uninstalling followed be reinstalling and then restart my laptop and nothing, the laptop doesnt recognize it so i cant start oneclickroot, im honestly bout to throw this P.O.S laptop out a window! someone help b4 i do something stupid, or if you can point me to a thread/other forum where i could get help
If you have installed the drivers and have your phone in debugging mode when attempting to connect and run OCR then it is very possible the stock cable could be giving you problems.
The cable that I use is from old Blackberry. This cable is way better than crapy cable from Sammy. :).
i was thinking that, time to go to the store
I hope you root your phone. You will have a lot of fun afterward. If you can buy a blackberry cable they are the best. Stay away from the HTC cables. They are not good!!!
Reactions: m.dot
ok ill try that out then, ha and i was about to buy the stock samsung one on amazon, thanks for the advice
I did the EXT4 from ECO5 OTA, got cwm3, and got syndicaterom standard put on (took 2 tries), but as soon as I unlock, launcherpro, gmail and desktop clock FC in infinite loop. How do I get out of this loop and then what do I do to address it. As it stands, the phone is nearly unusable. I'm going to keep reading.
EDIT: Apparently when i did the 3x wiping etc,etc, launcherpro must have still been stuck in there from the stock install. I re-did the 3x wiping, and all is well now.
I did lose all my info, and recently did a mybackuppro backup of data and apps, and last night while rooting i did a titanium backup. Which method should I use to recover at least the apps and contacts?
Try booting into CWM and wipe cache and dalvik cache, 3x and then reboot.
gbTopaz
