Root timeline
Re: Root timeline.
I will root it just for the custom kernels and CPU control to overclock/underclock.
Re: Root timeline.
I probably won't root till I need it, either when customisation comes along or when something I want to do (backup for instance) requires it.
Re: Root timeline.
That doesn't change anything about tethering being locked down, whether you buy outright or not.
Re: Root timeline.
I'm hopeful that ICS will do a better job of managing CPU clock speed when not under load, but if for some reason it doesn't then I may root in order to be able to underclock the device when asleep.
Reactions: bbhybridchris
If it runs stock Android I won't have a need to remove bloatware, so I probably won't have a need to root.
If everything works great without tweaking, then I'm good.
Sent from my GT-P7510 using Tapatalk
No root for me. I use the Good For Enterprise app to access work email and Good has administrator controls that will disable the app if root is detected. I would love to root for the WiFi tethering but work email with Good is more important.
Sent from my ADR6300 using Tapatalk
Re: Root timeline.
When I bought by DX, I waited a couple weeks to root:
A) so I understood what I was doing
B) because I wanted to really use my phone heavily to determine if it was bug free before technically voiding the warranty
If I need to have my DX serviced, I know how to flash back to stock and erase any traces of root, but does anyone know if rooting a Nexus device will still void the warranty?
Assuming it would, I'll probably wait a few weeks to determine if my phone has any hardware bugs.
@ diest ; rooting any device will void the warranty. Just make sure you know how to return it to stock and you'll have no problems with said warranty issues.
Good luck!
tap'n
Re: Root timeline.
I know that the second I have it I'll be trying to root it and unlock the wireless tether. And then beating my hands bloody because it didn't work and VZW found yet another way to block my tethering. Then climbing the walls waiting for someone to figure out how to tether. When the dust settles 5 minutes after the device is released someone will have an answer to rooting/tethering and all will be right with the world.
Re: Root timeline.
I know I'll be rooting it very soon after acquiring it. If for any reason to just be able to access the hardware settings.
ill be rooting the damn thing right in the store as he is still trying to activate it lol
hiredbyskill
