Rooted Lg Optimus Elite Mobile Network Loss Help
d34d85
3
So here is my situation. My carrier is "Lifeline" not virgin mobile. Since i rooted my phone i loss my mobile data. I have been looking around on this forum for any possible solution on how to retrieve/activate data. i even tried the self assistant activate.apk but it didn't work. I also did the ##786# but nothing happen or the other code and i went on phone information the same thing nothing. Everything works wifi, text, calls, just my mobile network is not working. Any help or solution will be great.
It sounds as if whatever you used to root the phone did some damage. Reflash the stock ROM and see if that brings it back.
Thanks for the reply, Reflash the stock rom you mean unroot it? also, i use "Rooting Your Optimus Elite The Easy Way" then after i flash the custom rom beta cm9 for vm and sprint. I did a full wipe, then installed the rom then installed the gapps then i rebooted the phone and everything was fine except my mobile data.
So you're saying your phone is sprint? But it's on lifeline or is your phone Virgin Mobile but you have it on lifeline? I'm a bit confused also have you tried the stock ROM?
RichardDixon
