prowlingfox
- Apr 13, 2011
- 359
- 51
- 0
i think i'll just go with this option. it feels like the easiest way to go and i'm so tired. i'm probably going to have recovery nightmares tonight!
thanks for your help!
Sounds good. If you decide you don't your ROM, you can switch between ROMs that are intended for the same radio (in this case ZVD) without returning to stock. So, for example, if you flash CM7.2 but decide you want to switch to RebornROM instead, you can just boot into recovery, wipe system, data, and cache, and then flash RebornROM.
If you would like to try HydroROM or gROM, just flash the official Froyo/ZVD update.zip from Xionia, then reboot and flash again from 3e, and that'll get you back to stock 2.2 firmware & recovery. From there, you can update to official Gingerbread/ZVH, re-root and reinstall Xionia, and then flash HydroROM or gROM.
If you have any other questions, shoot me a PM or post here! Good luck and sleep well tonight!
