Running Evervolv Gingerbread ROM
Awesome! i knew it was good for something. I will try right away, also i am now trying out that Bliss you mentioned, it looks like what would happen if Cm and MYN had a baby! By the way i keep getting this google.gapps message when trying to open my gmail, and sync my contacts, any suggestions?
I'm not sure what that is as I've never encoountered it, that theme is a little different than most themes and needs some attention when you install it.
(edit: clean install of CM!) You have to do a clean install at first, then load it up once without the theme, reboot and clear cache & dalvik, then install the theme and the revo battery mod if you want, then load it back up with the theme and go to menu, settings, cyanogen settings, user interface, tweaks extras, select a theme and pick project_blisshd.
Also of note in CM6 roms (theme or not), at any point after installation you should go to menu settings cm settings, performance settings, vm heap size, change it to 24, reboot normal, go back to the same place and change it back to 32 and reboot normally again. For some reason though it says 32, it never really is until you do this.
Ok, so I didnt know this, so now i am stuck at the HTC Evo 4G white screen...what do I do?!
Ok Fred, so i simply rebooted the system , and it worked...it has the theme on it, do i need to do anything? wait the keyboard is not there...so should I go to settings like you said?
phatjoe824
