S Planner reminder settings gone?
Re: S Planner reminder settings gone.
I have the exact same problem with my old Galaxy 4.
Since I had the phone unlocked the reminder and other features in S Planner have disappeared.
I've looked through every option in Application Manager but cannot find a solution.
Perhaps the only thing left to do is try a factory reset and then perform a smart switch between my new S5 and the old phone.
If you have an answer for this problem please let me know.
Roundtablequote has it right.
Do this Patty:
The answer seems to be the following:
"You have to go in to "Settings", "My Device" then change your "Home screen mode" to "Standard mode" to get the reminder field. This is a big PITA for my wife, she needs the reminder functionality but also needs the big images so I may yet turn to Google Calendar instead, but that's my problem. Mybe this will help yours."
I have had mine in basic mode I guess, so I took this advice and now have an Android phone, rather than the "big letters" version.
Best,
B.E.
I dont know if you guys found the solution but I also didnt find the task/reminder option in splanner and i found this post. I didnt have enough time to read all the responses but anyways i found it myself then. Here are screenshots for help.
So you basically click the Add event (i have the phone set to my language), and in there you click the thingy that i circled with blue color. It then opens and option to add events (the first three from the list on the next screenshot) and tasks (the last two on the list on the second screenshot), and you click where i circled with blue on the second screenshot. The last screenshot is basically a window where you then type in the thing you want to be reminded of and the date to remind you. I hope this helps
Oh and maybe for some more clarifications the word ''Dogodki'' means ''Events'' in English. The word ''Opravila'' means ''Tasks'' in English (Moja opravila=My tasks).
Hope this helps.
Djmanitas89
