S10+ reception...
Status
Not open for further replies.
S10 variants have volte, can talk and use data now.
S8 and a few others have the capability when added via software update.
Ok...so that's a capability of voLTE? I was wondering what it is/does. So far my experience is the call quality is lesser on voLTE.
I have Sprint but I don't have the phone yet but I'm getting unlocked I hope I don't have problems. Will I be able to surf and talk at the same time? I guess my husband can try it he has the same phone is it a setting you need to turn on Volte? I don't think he's been having reception problems but I'm not sure.
Ok...an update of sorts happened last night. It was not a normal system update, and it happened automatically. No notifications or anything except while it was happening.(I forget exactly what it said).
But..
Reception changed instantly after the update happened.
I'm not near my house until later today, so I can't speak of my "home" reception yet which was bad too.
Where I am currently and was all day yesterday I was sitting on a full signal roaming network. Texts etc were stacking up and "downloading" but coming in every once in a while..
After the update:
Network switched to full signal LTE. All of my texts downloaded within minutes. Like new. This is how it's supposed to be.
I will report back tonight or tomorrow with home signal updates. Hopefully that was the issue and all is well now..
Update:
Reception near my home hasn't changed. Still will go from 4 bars LTE seldom, to zero and just an "x". "Emergency calls only" and texts take forever to send and receive.
I got an update this morning. Nothing changed. If you disable Band 25 and Band 41, it seems to have helped a ton.
Directions: You must disable Band 41 AND Band 25!. Enter Data Programming Mode: ##3282 # Edit -> Enter MSL: 000000 -> OK -> LTE -> Band41 Enabled -> Deselect -> Band25 Enabled - Reboot. So far seems to fix the issue. Again, you must disable both Band41 and Band25! Works like a charm Smiley Happy
wow! so I was thinking of upgrading - maybe not. I like a phone that works to make calls and stuff.
Though - I wonder how much is related to the crappy network sprint is.
Update came through tonight....I'll test tomorrow and be back with some responses tomorrow..
Curious how and where you came up with this fix?
Sprint has ordered me a new replacement s10+ and will be delivered by Tuesday.
Since this seems to be about the Sprint issue I am going to close it down so we don't have two threads going on the same thing.
Status
wobblefix
