S20 Firmware For Odin Flash?
You need to flash the firmware and the the tmobile user data file then your phone should boot up with tmobile boot splash and all its bloatware
I have a Verizon s20 ultra with att firmware and I get att boot up screen and all carriers bloatware , wifi calling works and data over LTE works so yes he can flash the U1 firmware then he needs to flash the U firmware with the tmobile users data file
I'm currently been testing a demo s20 ultra just added a imei and so far everything is work good on tmobile and att.
All carriers firmware are universal so if its sim unlocked the sim in the phone will load the carrier provisions
How you get a demo model?
Thats the thing with the s20 series if you want the carrier bloatware you need to flash carriers userdata file especially att if they want wifi calling etc... its not like the note series when you install the sim it will automatically boot up to that carrier and bloatware will automatically load up. Believe me lol........And I unlock phones repair imei and what not and I came across this demo mode. Any demo that can reboot to recovery and do a factory reset you can apply a new imei and everything will work.
For the US version s8 to s10 series including the Note series , carrier firmware are unerversal , i dont think they changed it with s20 series from what I heard, so if its sim unlocked it will dictate what gets loaded on it , and believe me I've done a lot of flashing.[ Applying a new IMEI is a different thing and Not allowed to be talked about in the Forums ] US unlocked versions are different .
Exactly but you asked me lol....believe me if you have a Verizon s20 ultra unlocked and you put a att sim card it will not have wifi calling nor att bloatware will Will not boot up with att logo.....I've been doing this for along time since cupcake. Lol
I'm in California so I know whats the difference lol.....even with the s10 plus 5g if its a att unlocked and you put a tmobile sim card it will not load tmobile bloatware splash screen.
Yes Verizon model are little different, but I had tmobile version flashed to Verizon firmware and everthing worked , wificalling, download booster,carrier provisions ,splash screen tmobile , same with Att on on Verizon firmware . Key was it had to be sim unlocked to load different carrier splash screen and provisions, as it prompts you to restart and reconfigure.
I have two Verizon s20 ultra unlocked and a customer has att when he put the sim card it didn't not load anything att nor wifi calling , until I flashed the att userdata then he did. Tmobile is different from att alot different.
But it's all good bro.....we know what's up . Just pretty much for att users.
Definitely stay safe
Xtmanual
