S20 Firmware For Odin Flash?
Yes phone shows U1 but VZW/VZW/VZW. I think its cause i left my sim in while flashing. Saw a huge drop in battery life these last 2 charges PS.
While I was on U1, I had no bloat or carrier Bootloader. Once i flashed the TMB U firmware, it reinstalled the VZW bloat, boot, and kept the VZW CSC
That sounds right , the VZW/VZW/VZW
the last VZW means it's originally Verizon phone and the first two means just the carrier that's in the phone or last sim in the phone.
that's the problem. the last sim card and the carrier im on is T-mobile. The only Verizon about this is the phone was bought from verizon and they unlocked it when it was paid off.
I can't get the any other carrier settings to install other than verizon. When im on U1 its all cleared at least
Sorry for the rehash...
I am one of the lucky many that never gets OTA updates from ATT (USA). It began when I moved from the s7 to the s10...I ended up ditching the s10 coz I hated it and got the s20...well this doesn't update either. Have spent years on the phone with ATT and we all know how that goes.
Since ATT can't OTA me I am going to flash the latest firmware via Odin...per all the excellent instruction here.
ATT firmware not available so I am going to flash the latest from TMB.
Phone is SM-G981U
Locked to ATT (ATT Sim)
Current firmware is G981USQU1ATAW (Android 10 UI version 2.1)
Security patch is 02.01.2020
I have downloaded G981USQS1CTL1/G981UOYN1CTL1/G981USQS1CTL1 via Frija
Understanding which files go where after unzipping...
Just to be 1000% sure sure...I am good to flash this TMB firmware on my ATT locked SM-G981U?
Thanks a lot.
ATT firmware not available so I am going to flash the latest up from TMB.
Phone is SM-G981U
Thanks a lot.
Yeah your good to flash Tmobile firmware, you might have to flash to next update if the carrier not on same build but just repeat the same while putting Home CSC file in the slot so don't factory reset.
Thanks.
Per the ATT site it says the latest firmware is supposed to be G981USQS1CTL1 (S20 5G). They have it listed as Android 10 and seems to be just a security update. (small file size)
On Frija they have it as R(Android 11)
Understood about the Home CSC file..also leave User Data empty.
Thanks.
If frija says andriod 11 thsts gotta be the latest, also it could be the att site not been updated , yes for the home csc and leaving the last slot in Odin alone .
Just to finish up my question and to post the results.
I flashed G981USQU1CTKH first as that seemed like the jump from Android 10 to Android 11. The flash was good and the phone booted up and loaded as expected. No issue with TMB firmware on this ATT phone.
Then flashed G981USQS1CTL1 which appears to be the latest update with the current security patch.
One thing I did notice is that accessing the DL mode is different. Hold volume up/down while plugging in a USB cord.
All is good, phone is updated and working like it should.
Thanks for the help.
Hi,
Let me apologize for the newbie question that you guys might have answered a million times. But since it's my first time I just wanna be sure so I don't brick my phone. I'm using an unlocked ATT s20 ultra (SM-G988U) with G988USQU1ATAW baseband. Since it's not updating itself, I would like to know which firmware to use and the complete instructions on updating the firmware. Would like to preserve my data. Can I use the unlocked version one since I don't need ATT add-ons.
Thanks in advance. Much appreciated.
Heya all, I am hoping this is the right spot to ask a couple of questions regarding my ATT GSM unlocked S20 plus that doesnt like to OTA update- it was stuck at January 2021 security patch flavor when I first got it. I read and read and read (thanks awesome people here too!) and I used Odin and currently it has been flashed (correctly) to now have July 2021 security patch level using G986USQU2DUG1 firmware from sammobile.com. My questions are thus:
1.Can (should) I flash it to a t-mobile firmware (found on sammobile too) so that I get auto/manual OTA updates from t-mobile (b/c ATT seems to be bleh) and I already use Mint (t-mobile network prepaid flavor sim)? I dont have any need/want for the ATT bloatware as I removed all I could already.
2.Is the above question possible since it looks like the t-mobile firmware available seems to be a predecessor/older than current firmware version I have flashed? I know with some custom firmware on other electronics, namely PSP and PS Vita, I could go back to an older firmware without bricking.
Thanks in advance again!
Your welcome!
Hi,
You can use unlocked firmware but it would delete data so back up you're going need , otherwise can use the other Carrier firmware like TMobile without factory reset but still back up.
You can flash the TMobile firmware , or unlocked firmware .
Cool, thanks too! I guess I will try and see if the neutral firmware that I have currently updates well OTA...I just had really good luck with t-mobile pushing updates to my S10+ in the past, so that is fresh in my mind. Here and now, checking manually seems like it immediately says "....is current" without even giving much effort so I think it times me out to really check once every 24 hours.
No problem
Yeah Keep checking manually periodically , if not I can assist you with Odin.
Hello,
can someone please explain to me how to go from Verizon G988U to flash it with AT&T carrier settings in order to have wifi-calling?
Hi Mustang,
you were just helping me with my question I posted prior to learning about this thread, but I figured I'd move my follow-up here as I didn't see it addressed.
When I installed Odin it mentioned deleting the Samsung and Google accounts. Does this need to be done prior to the update?
Hi Mustang,
No you don't need to
Sent from my SM-S908U1 using AC Forums mobile app
I had a similar problem when I bought mine a year ago. It's the first time I bought a nice phone with all of today's features. I'm not familiar with all the terminology and lingo, bells, and whistles. And my funds are somewhat limited, so the latest model isn't happening. The Galaxy S21 looks uglier anyway. So I decide to get a Galaxy S20. It has a pretty light blue color. Isn't too bulky. And a sleek glass back. And expandable storage. The seller said it was unlocked. And tells me it will work with Verizon. When I receive it, I was disappointed it had a T Mobile startup screen and some other T Mobile app that I couldn't get rid of. I move my SIM card over to the new phone. And it works like it should for 2 months. Then Samsung forces some update. And all of a sudden, my phone becomes almost useless. I can't make calls anymore or most other functions that require service. I take it to the Verizon store 25 miles away. I'm on a family plan. And I'm not in control of the account. So, the help there is somewhat limited since I don't know the PIN number. The associate puts in a new SIM card. Resets everything. Changes other settings. Nothing does any good. The associate says the T Mobile programming locked on it is likely the problem. And that is why the SIM card isn't read.
Soon thereafter, I call Verizon technical support twice. After a long time on the phone with them giving information and changing some settings, I get disconnected. The phone still won't work right. I ran out of patience and bought a new phone. And made damn sure it didn't have any network programming locked on it.
This time, it's a different headache I have to deal with right out of the package. Now it won't charge right. Every cable keeps slipping out. So I take it to a repair store 25 miles away. Whatever they did, it still won't charge right. At this point I'm thinking I'm going to have to return it to the seller. But I take it to another repair shop since they got good reviews. And I really don't to wait 2 weeks for another phone. Thankfully, the awesome employee here finds some tiny wrapper stuck in the port. I would have happily paid a fee, but it didn't cost anything. And the cables no longer slip out. Since then, it runs like it should, mostly without any problems other than the network dropping every now and then. So after 2 major headaches, I learned the hard way carrier unlocked is not the same thing as factory unlocked.
iceteanice
