S20 mms fails to load while on WiFi
I just got an update for my Google Messages app so maybe that will help you guys? I am a beta tester so I'm not sure if that was a beta or regular update. Just keep fiddling with it and it will work eventually.
This problem used to come and go for me on T-Mobile. The last time it happened when I first got my Ultra I read somewhere to select 'cellular preferred' if you keep wifi calling on. I don't think I've had the issue since then. I'm not sure how that effects what network is used for calling or if that is a concern I'm the grand scheme.
I don't have AT&T to test this myself, but try going into the developer options in your phone's settings, look in the networking section, and turn on the "mobile data always active" option. When on wifi, you'll use that for regular data use, but will hopefully allow it to remain ready to accept MMS messages.
I was having the same issue on my Note20 U, but this seems to have fixed it. Thanks!
uOttawaGrad_22
