S22 Ultra Battery Disappointment
If you guys are having battery issues, try out the following:
1) Use dark mode (OLED screens do not use battery when displaying black, and use the most power to display white). The screen is usually the most power hungry component on the entire device. Also use auto-brightness.
2) Go into the individual app settings and disable background data usage for problematic apps that love to keep your phone awake such as social media, weather, news, etc. If it updates when you open the app instead, usually that is just as good and does not affect usage. Some apps constantly check things like your location as well.
3) Go into the individual app settings and set background data usage to "Restricted" for those same apps, or anything that doesn't need to be running as a background process while you sleep or whatever.
4) Don't let the phone constantly scan for and alert you of nearby WiFi networks
5) Don't let the phone wake up it's entire screen when you get a notification, and disable the always-on display if you don't need it (personally I use double tap to wake/sleep along with brief notifications).
6) Disable the "always listening" (Hey Google) for Google assistant unless you need that
7) If you really want to get into it, use Bixby routines to set some schedules (if you aren't familiar with it, they are basically powerful if/then statements) to control things that use battery life. For example, you can tell it to put the phone in battery saving mode if it's past 11pm and your phone isn't charging, and disable at 7am. There are unlimited options there. Bixby routines is actually extremely powerful.
8) If you get tons of notifications overnight, leave your phone on silent or DND rather than vibrate
And more broadly, treat your battery well and it will stay close to maximum capacity for much longer if you aren't someone who gets a new phone every year. Never leave it charging overnight (especially if you let it charge to 100% and don't use the 85% "battery saver" function). Don't let it sit at 100% charge for long periods of time. Don't run it down to 0% or really close to 0% on a regular basis, especially if it's cold. Don't let it sit somewhere extremely hot or cold for any extended period if time. Don't fast-charge it unless you need to (heat degrades lithium batteries faster).
I lose 1-3% over an ~8 hour sleep, exactly the same as my iPhone.
I've had mine for almost 2 weeks and battery is not great.... I will compare it to my 13 mini maybe even a little worse.
Whoa. That is not good to hear. Mine gets delivered tomorrow and while I know my 13 Pro Max will likely deliver better battery (that’s an understatement) I hope the S22U isn’t a horrible disappointment as far as battery but it won’t be my daily driver anyways.
I keep reading reports of disappointing battery life but I hope if I run at 60hz and FHD+ it’ll be decent.
Whatever you do don't choose
"Limit Apps and Homescreen"
under Battery Saving options.
I did and it wiped all of my shortcuts to various browser sites I use often. Some other things disappeared from folders in Nova Prime as well. Took hours to get it back the way it was.
Good tip yes it will do that
My battery is pretty good also, but I'm not a power user like some of you may be. It's pretty much the same as my S21 Ultra was, and I can go two days without charging sometimes.
It's hard to beat the Iphone 13 pro Max, but it even drains pretty rapidly when I'm using it heavy. It just depends, and I have to give it a few more weeks and when I go on vacation to really see.
Whether or not you're a "Power User" depends on what someone means by the term "Power User". Most people who call themselves "Power Users" to justify high battery consumption are actually "Heavy Users" and do not meet the definition of "Power User".
Where can I find the definitions of power user vs heavy user?
I have no issues at all with the battery life and am extremely happy with it. It is far superior to my old Note 9 which from day one was never good on battery, let alone 2 years later. I am now back to having the AOD and my overnight drain is less with AOD on than my old Note 9 without it. And even if the battery life wasn't that great, I'm very pleasantly surprised how fast the 25W charger performs.
I'm in Australia and to be honest, I wouldn't have upgraded to the S22 Ultra if it was bundled with the Exynos processor.
Maybe a couple of tips to help others:
1. Put Chrome and Samsung's internet browser into dark mode. You're better off using Samsung's browser, as Chrome only loads its home pages in dark mode, whereas Samsung's browser loads all web content into dark mode.
Put YouTube into dark mode also.
2. Put the phone's theme into dark mode.
3. Forget the fancy 120 Hz adaptive refresh rate. The scrolling at 60 Hz is plenty smooth and will save battery.
4. Under connections, click off 5G and select 2/3/4G.
5. Under battery and more battery settings, make sure adaptive battery is toggled on and processing speed is selected to optimised.
6. Toggle on, "put unused apps to sleep”, under the battery section.
7. In the same section as 6., I have put all my apps under sleeping apps, so they all run sparingly in the background.
8. Use dark, non animated wallpapers for the home and lockscreen.
9. You will not notice the difference between FHD and WQHD. So select FHD and select screen mode natural, not the over saturated and power sapping vivid.
10. Here's a little lesser known tip. I love the S pen but like I suspect most people, don't use the remote Bluetooth functions. If you don't use that either, turn off S pen functionality. In that way, the S pen is not drawing power from the battery in the phone's pen silo.
As an aside, if you intend keeping the S22 Ultra for more than 2 years definately turn on battery protection and don't use wireless charging.
I hope that helps.
I hope that helps.
These are excellent tips in my opinion. I know some will not want to limit there shiny new phones but these tips seem golden to me and I've set them. I'm looking forward to seeing how much these help. Thanks!
Hey thanks. I actually think there is extremely little limiting in these tips. I find FHD more than good enough screen quality and 60 Hz refresh rate more than smooth enough scrolling. I have never even bothered to try the 120 Hz adaptive refresh rate as I'm completely satisfied with 60 Hz. The only limiting suggestion is turning off S pen remote functions and only for those people who never use it.
Let me know if these tips helps battery life for you.
I sure will!
My second go 'round (after doing factory reset and setting up clean) I am finding things are settling in nicely...
At first glance this looks pretty bad, but this was A LOT of outdoor use in the bright Georgia sun and I took a TON of pics ... Mostly on WiFi but some 5G usage in there too. I have adaptive brightness on, motion smoothness set to adaptive and resolution set to WQHD. I do keep AOD set on "show for new notifications" but that's not to try and conserve battery just my OCD not being able to tolerate a screen in a constant on state LOL.
Not sure this can qualify as "great" battery life, but this is fine with when coupled with how ridiculously fast this phone charges! I'm using Google's 30 watt charger I picked up when I purchased the Pixel 6 Pro and it charges my S22 Ultra crazy fast! (From 35% to 100% in a little more than an hour ... Give or take)
Haven’t googled the two but if I had to try… A Power User is a term used to describe a person and their needs from a productivity standpoint. A person that can and does basically everything one would do in one’s office from their phones from calls, texts, meetings, working on files, etc.. everything… manage their home and work needs from that phone throughout the day and needs a phone that can last it.
A heavy user is just a general term for someone that’s on their device just as long throughout the day… could be work, could be leisure watching Youtube or texting or Snap Chatting all day. Their device is unlocked/on more hours during the day than off.
A light user isn’t on their device all day so battery life is not a critical to a light user than a heavy user or a power user.:)
I only had an S22U for four days; however, the first three days I used it extensively from loading and setting up apps from the app store, playing with the S- pen for hours, going over almost every option to customize the phone and playing with the pro camera/expert raw mode on the camera I used it a hell of a lot.
And I had no problem with the battery usage for any of the days it was in my possession.
And the only battery saving feature I had checked off was Dark Mode. And not due to battery savings, due to it is easier on the eyes. I had the screen turned up to max resolution, full 120 hz, etc. (I paid for it I'm going to use it.)
If I had found the battery to be too weak for my usage; I would not have re-ordered the exact phone this AM from Amazon.
After 6 days in I was a bit concerned with my battery life so I decided to bite the bullet and factory reset and set up clean (no app or data restored). I typically set up all my new devices clean, but got lazy this time LOL
It's not even been 24 hours since I did the reset so it's too early to say for sure, but I already feel like the battery life is better than what I experienced the first few days. Hopefully as it learns my usage patterns it'll get even better.
I was having serious buyers remorse with my Ultra with getting seriously laggier day by day, apps misbehaving, phone always getting hot and the battery really sucking but I also took the nuclear option and factory reset mine after 2 weeks of use too. Absolutely hate doing this after taking so long getting everything the way I like it. I set it up as a fresh new phone this time. Last time I only used the backup method to install my photos and settings from a previous phone but whatever the issue was is gone now. What a difference in speed, performance and even the battery now. I really thought I'd got a defective unit even though us Exynos buyers already have a hand tied behind our backs to begin with.
Yeah, no one likes the dreaded factory reset but sometimes it is the best solution.
As I've used mine these past few days I can definitely say it can't come close to my iPhone 13 Pro Max in battery life but, for me, that was pretty much a given. That said, it's understandable. Can a Android phone be this liquidy-smooth, powerful, capable, huge, and have insane battery life? Perhaps not. At least not...this year. It feels subjectively faster than my 13 Pro Max and that's at 60hz though. I mean its nasty-fast-nasty and as smooth as glass.
My partner doesn't understand why its always in my hands. Honeymoon phase, I suppose. I've never had another android device that was this liquidy smooth. I can typically get to a charger so the decent-but-not-great battery life is fine. So I'm running it in the aforementioned 60hz in FHD+ (my eyes don't seem good enough to discern a notable difference between FHD+ and WQHD+) and it all good.
Battery life is more than good enough for me, so far.
Dsignluckmezc
