S4 Camera features are missing
Its unlocked.
I dont have a carrier on mine.
And exactly! I don't know how to fix it though!
Are you in the States or another country?
And even if the phone is unlocked, you must have a carrier to give you service, hence my question.
Sent From Inside The TARDIS in a Galaxy S4 Away!
Bushra, I'm beginning to think you have a fake GS4! :eek::confused:
You should really look into that or return it.
How much did you pay for it?
First , I thought its Galaxy S4 Mini or something.
Its not galaxy s4 but again model number says i9500.
So I think its fake one.
Hate to say it, but this seems most likely. None of the screens OP has posted look like my phone. Mine's the i9505, but they should be the same
Stargate, you got 3625 posts. I hope the rest of your advice is better than this one. She has her phone in "Easy" mode which hides a lot of apps settings as well as a simplified home screen.
I'm not sure why after all this time, instead of helping and giving advice, you attack me.
Look at Bushra's screenshot below your post. Then look at my screenshot at bottom, mine is with Easy Mode on.
You'll see they are not even alike!
This is how my camera looks.
There is no Mode option at all, even in the settings
Sent From The Pegassus Galaxy With My GS4
Hi guys,
I am suffering from the same problem. I bought a brand-new Samsung 4S (GT-19505, 4.2.2) a couple of months ago. All the camera functions worked at the beginning, but I lost some of them after a month or so. For example, there is no dual camera function now, and I cannot zoom in when I use camera modes.
Any suggestions?
Devo
All good now. I changed the view from "Easy" to "Standard".
All the camera functions are back.
Thanks.
Devo
Hi guys,
Any suggestions?
Devo
Hello and welcome to the forums!
Have you checked if you are on Easy Mode?
Check my screenshots on this thread for reference, the last one is on Easy Mode.
Thanks.
Devo
For some reason I didn't see your last post. I see you had it on Easy Mode.
Hope everything is working good now.
I have a similar same issue. I'm NOT on easy mode, never have been, never will be. I went to the settings within the camera and reset the camera settings. Everything came back..........for a second..... then a message poped up about burst shot and **POOF** I'm back to only six options. Also, a couple of my albums disappeard about the same time i noticed the modes were MIA.
When I reset the settings, those came back, and stayed ....so far
Please help!!!!
dual shot and camera setting of my s4 was missing. i can't zoom in and out it while taking pix as well. What should I do to fix it? Thank you
Taylor Bag
