S5 low battery
  • Start date Start date
A
AC Question
Is there some easy way to put the S5 back to previous settings after it has gone into power saving mode? I find that when the battery gets below a certain % it set my ringtone volume on low, stops Gmail sync, dims the display, switches off WiFi, switches off message alerts and a bunch of other things. It's a pain having to remember to go back and re-set everything whenever the battery gets low. BTW I'm not talking about Ultra Power Saving Mode, just regular low battery.
Hello. I have a Note 3. If you press Power Saving Mode in the General settings (not the switch on the Notification shade), do you have more options there?
Sent from my SM-N9005 using Tapatalk Pro
Nehasingh12
